Page 1237 of 1549 FirstFirst ... 113711871227123312341235123612371238123912401241124712871337 ... LastLast
Results 12,361 to 12,370 of 15485
    Feb 2015
    #12361
    Question sirs, paano nyo napagana yung stock head unit ng innova j para magplay ng music using android cp? Salamat.
    Jul 2016
    #12362
    Quote Originally Posted by ronaldmb7 View Post
    Kung parehas lang sila sa innova e. Yung audio jack cable sir ginamit ko papuntang android fon to play music.
    Sent from my SM-J500G using Tsikot Forums mobile app
    Jul 2016
    #12363
    Question sir. Plan ko diy flush ng coolant. Ano tools pam bukas dun sa top ng radiator natin. Wala kasi radiator cap yung sa innova?
    #12364
    Quote Originally Posted by oliver1013 View Post
    Di ko na pala ginalaw ATF ko, sabi kasi sa manual, every 40,000 inspect lang, unless driven at a certain speed for a number of hours which I never did. Tsaka mapula pa yung fluid. So tipid pako as of now
    Bro.,- read the manual again,- there is a segment/statement that you need to replace it every 40KKm when you use the vehicle in severe driving conditions (heavy traffic and high temperature - which is typical of MM traffic condition - cannot remember the exact temperature [number] written)....
    Anyway,- it is your ride,- so your call....
    _/_/_/
    30.8K _/_/_/_/_/_/_/_/_/_/
    May 2009
    #12365
    ang "tool" lang na kelangan e yung mala-vise grip na mga kamay para maluwagan yung reservoir bottle at yung drain cock ng radiator
    dun din sa reservoir ka maglagay ng coolant kasi may hose connecting yung bottom ng reservoir bottle papuntang lower tank ng radiator. fill mo lang up to B level then bleed mo lang ang system by letting the engine run up to operating temperature.
    Jul 2016
    #12366
    Quote Originally Posted by miked View Post
    So sa reservoir lalagay water sir para pumunta sa radiator ang tubig? May nag sabi kasi sakin bubuksan daw yung parang malaking allen range bolt sa top ng radiator ng innova. Dun daw mag lalagay water pag flushing.
    Sep 2006
    #12367
    [COLOR="#008080"]
    question po. first time to do this outside the casa, 80k na yung innova ko.
    pwede na ba yung simple drain and refill, which i've read will use just 3L of ATF? or dapat dialysis talaga which will use around 8-9L of ATF?
    any shops outside casa that can perform said dialysis (preferably near new manila/qc area)?
    Jan 2009
    #12368
    Quote Originally Posted by ptk675 View Post
    Really depends upon your willingness to spend. A dialysis exchange will always be better than drip and fill. However, the associated cost is not always commensurate to the benefits.
    If your A/T isn't experiencing problems and the old ATF doesn't show any signs of abnormal wear, drip and fill should be enough at the prescribed PMS duration.
    The same cannot be said if the transmission has been abused, neglected or has been contaminated/inundated. If that's the case, a dialysis would be preferred.
    Equally important is to use the correct ATF. Better to stick with Toyota OEM.
    May 2016
    #12369
    mga kainnova, ano po maganda gamiting gear oil? (Innova 2005 diesel manual)
    ok po ba yung caltex gear oil o magstick na lang ako sa toyota transmission/differential oil?
    and how much po labor po pagnagpapalit gear oil? TIA
    #12370
    I take it that you meant [you stated that this is the first time to do this outside the casa] that the casa has replaced your ATF during your 40KKm PMS with them.
    You ask around first bro,- for the availability of an ATF dialysis machine from your gas station/local car shop.
    Then, your call whether to drain and refill (about 3L, yes) or dialysis (about 10L), based on your budget and risk appetite. More importantly,- I suggest you buy the ATF from Toyota....[their manual nor their ATF carriers do not state what international standard their ATF is...]
    _/_/_/
Toyota Innova Owners & Discussions [continued 3]
