Results 14,911 to 14,920 of 15485
- Jan 2008
- 4,726
February 22nd, 2022 11:35 AM #14911pag naka salang na sa wheel alignment machine, check mo yung readings.. make sure na within tolerance lahat.
yung pag kabig nyan, minsan nasa gulong mismo.. ganyan nang yare dun sa adventure ko eh..
nag rotate ako ng gulong.. then check alignment.. ok naman.. inadjust pero hindi maayos kumakabig pa din..
pinag palit ko ulit gulong, then check alignment and make sure na within tolerance lahat..
conclusion, nasa gulong nga.. hehe
tsaka minsan nasa kalsada din.. kung sa kanan pumupunta, ok lang yan kasi yung roads natin naka hilig sa kanan talaga
ang mahalaga dyan eh pantay dapat ang upod ng gulong.. minsan kasi kaka reklamo natin sa wheel alignment, yung technician gagawin nyan eh dadayain ng konti yung adjustment to compensate sa nararamdaman mo.. ang result, tuwid nga takbo pero hindi pantay upod ng gulong
- 54,262
February 22nd, 2022 12:12 PM #14912i assume it's the white cylindrical object and not the black hose.
if the replacement filter isn't too expensive naman,
and the said filter isn't designed to be cleaned and re-used,
i'd replace it na lang.
just looking at it in the picture,
i do not see how i can effectively clean it.
- Sep 2021
- 903
February 22nd, 2022 01:54 PM #14913Parang sealed type na disposable item yan.
You can take it apart and clean it, but you'll never be able to put it back together properly without it leaking/failing later on.
I also suggest you simply replace it. Whatever amount you may save now trying to tinker with it, will come back at you later down the road.
February 22nd, 2022 02:01 PM #14914
February 22nd, 2022 02:17 PM #14915
Bought a pack of those filters online. I replace it once a year.
- Aug 2013
- 262
February 22nd, 2022 02:55 PM #14916
February 22nd, 2022 04:40 PM #14917
- Jun 2005
- 3,774
February 22nd, 2022 06:15 PM #14918How about getting this?
Sent from my MI MAX 2 using Tsikot Forums mobile app
- Jan 2008
- 4,726
February 22nd, 2022 06:34 PM #14919di ba fuel return filter yan? parang masyado maliit para maging main fuel filter yan
February 22nd, 2022 09:37 PM #14920
Same design language across the range is fine Porsche, Audi, VW, Lexus and Mazda are all like...
China cars
