Page 1229 of 1549 FirstFirst ... 112911791219122512261227122812291230123112321233123912791329 ... LastLast
Results 12,281 to 12,290 of 15485
    Jan 2013
    #12281
    Toyota casa would quote for about 3L...
    Dialysis we did a few months ago, I used 9L.
    Sir cvt, san ka nagpa dialysis at magkano inabot?
    Apr 2010
    #12282
    palitan ko sana cabin filter, inquired Gant kung magkano, 900 OEM and 300 for replacement
    binaklas ko and may konting dried leaves and lint, at maitim. washed it with detergent and brush. eventually papalitan rin pag numipis na due to constant washing, hindi yata talaga washable yun
    next project ko ay DIY oil catch can and fuel filter replacement. saan bagay ilagay yung OCC and pano ang mounting?
    Mar 2016
    #12283
    Quote Originally Posted by ParticleX View Post
    Bili ka nalang ng oil catch can, tapos ikaw nalang magmaintain at magrepair if needed. one time lang naman.
    #12284
    Quote Originally Posted by homhomnova View Post
    A regular Shell gas station in your neighborhood should have the dialysis machine bro.... It is now a fairly standard car service equipment....One was just outside the village.
    I bought all of the ATF from Toyota Alabang. I do not remember now the cost per liter. I remember paying P500 for the service....
    May 2012
    #12285
    ^mura lang pala, dialysis na yun sa shell
    akala ko 1k-2k damage
    kahit ba 4-5yrs palang need pa dialysis? or kahit drain nalang pede na?
    Mar 2012
    #12286
    biglang umilaw yung airbag icon sa dashboard habang nag dra-drive ako. kaya ang ginawa ko, pinatay ko yung makina at start uli. nawala naman yung warning sign. meron bang naka experience sa inyo ng ganito? after now. ok naman na. almost 5 yrs na yung innova J gas ko. TIA
    #12287
    Quote Originally Posted by gygie View Post
    i don't know if this is connected.
    but there was a recall yata of the spiral cable a while back.
    would you know if yours is/was included?
    Mar 2012
    #12288
    thanks dr. d. saan nyo nabalitaan yung recall? para saan sir yung spiral cable? tnx sir
    Sep 2016
    #12289
    good day to everyone. mga sirs, i hope you can help me with my headache . my car, a manual transmission, diesel fed, toyota innova 2014, as i have observed, lost some speed or power. i dont know which is which (speed or power). explanation: 3 months ago, it used to give me a good speed at 2,000 rpm.
    at gear 1 it gives me 20km/h
    gear 2 --> 40km/h
    gear 3 --> 60k/h
    gear 4 --> 80km/h
    gear 5 --> 100km/h
    but now it gives me lesser speed for the same RPM (2,000rpm)
    gear 1 gives me 16km/h
    gear 2 --> 34km/h
    gear 3 --> 54 k/h or less
    gear 4 --> 80km/h
    gear 5 --> 90km/h
    in short, there is around 20-25percent speed reduction or power reduction regardless of the RPM (either 2,000 or 3,000rpm). i dont know which is which. i have asked mechanics and they gave me different suggestions - all of which never rectified the problem.
    oil change
    gear oil change
    fuel additives
    engine air filter
    engine oil filter
    fuel filter
    all done but the problem still persist . can you please enlighten me on what could be the problem?
    thanks in advance po sa sinumang sasagot at talagang masakit sa ulo isipin .
    Jan 2009
    #12290
    Quote Originally Posted by anonymouse View Post
    gear 2 --> 40km/h
    gear 3 --> 60k/h
    gear 4 --> 80km/h
    gear 5 --> 100km/h
    gear 2 --> 34km/h
    gear 4 --> 80km/h
    gear 5 --> 90km/h
    oil change
    gear oil change
    fuel additives
    engine air filter
    engine oil filter
    fuel filter
    When an engine is doing 'x' RPM, with the transmission set to 'y' gear, the resulting vehicle speed 'z' can be determined, as they're mechanically connected. In other words, if you measured it correctly the first time, the results can be reproduced and should give you the same results as before.
    If not, one of two things may be happening. The speedometer is not giving the same readout as before or your clutch is slipping.
Toyota Innova Owners & Discussions [continued 3]
