Page 1190 of 1549 FirstFirst ... 109011401180118611871188118911901191119211931194120012401290 ... LastLast
Results 11,891 to 11,900 of 15485
    May 2009
    #11891
    my sis' innova 2013 is having this initial noise(toktoktok, taktaktak, whatever) upon start-up. 21k plus kms pa lang. noise will subside within 5-10 seconds after start. hindi naman naka-on ang aircon so out of the question na yung compressor bearing.
    suspetsa ko e either the tensioner or the idler.
    tapos may nakausap ako dati na driver ng innova ng isang lgu, tumilapon daw dati yung isang pulley. can't tell kung tensioner or idler.
    i think napost ko na itong problem nun. pero lately tuwing uuwi ako sa bahay at yun naman gagamitin ko e parang nagiging regular na yung occurence tuwing kaaandar. wala e. di inaasahan na maging reyna ng garahe. okay naman na after that.
    i'll do some noise investigation (gamit ang diy stetoskok ko. hehe) later this month para malaman kung saan ba galing ang ingay.
    Feb 2015
    #11892
    Nakalagay na tire pressure sa may driver's side door ko ay 23 psi kapag mag-isa lang, 25 psi yata kapag may sakay. Parang masyadong mababa yata to? Bale 33 psi mga sirs pinapalagay kong hangin.
    Toyota Innova J unit ko. Tires is Yokohama Aspec 205/65R15.
    Oct 2005
    #11893
    Quote Originally Posted by ronaldmb7 View Post
    Ako sir kapapalit ko lang apat na gulong sa SnR Yokohama Aspec 205/65R15 and recommended pressure nila is 32PSI front and 33PSI back pag wala masyado karga pero pag loaded daw dapat 35PSI yung likod pero pinakarga ko na is all 35PSI for all 4 tires including spare na rin kasi di mo masasabi kung kailan ka ma full load and nitrogen na din hangin nilagay. Kagagaling ko lang Aparri using the 35PSI tire pressure loaded with 6 pax ok naman siya hindi matagtag and smooth naman siya.
    Jul 2013
    #11894
    Double check mo. Ang alam ko 33psi sa lahat kung isa or dalawa laman.
    Pag loaded 33psi sa harap, 35psi sa likod.
    #11895
    oo nga. masyadong malambot yan. 33 psi at least.
    sa driver side pillar ko ay 33 nakalagay....
    #11896
    Quote Originally Posted by fyke View Post
    magkano Aspec sa SnR sir?
    Jan 2012
    #11897
    Yung 23/25 po sa door means 33/36 PSi
    thanks
    Feb 2015
    #11898
    oo nga mga sirs e double check ko mamaya. Picturan ko para sure. Buti na lang kapareho ng inyo yung pinapalagay ko so hindi ako masasabugan ng gulong hehe!
    Feb 2015
    #11899
    Quote Originally Posted by 1natzt View Post
    thanks
    Noted sir. Curious, paano naging 33/36 psi yung 23/25 sa door sir? Salamat
    Jan 2009
    #11900
    I think he meant 230 and 250 kPa.
Toyota Innova Owners & Discussions [continued 3]
