Results 5,321 to 5,330 of 15485
February 6th, 2013 12:03 PM #5322
- Oct 2012
- 8
February 6th, 2013 12:28 PM #5323mga sir tanong lang..dati kasi may sasakyan ako mazda 323 pag aalis ako pinapacheck sa akin lagi yung tubig nun baka daw kasi matuyuan at mag over heat... nung bumili kasi ako ng innova tinanong ko dun sa ahente kung san tutubigan ung makina..natawa ung SA sabi naku sir di na po tinutubigan yung mga makina ngayon yung mga luma lang po.so ang tanong ko wala na ba talagang ilalagay na tubig? pasensya noob
thanks and more power
February 6th, 2013 12:47 PM #5324
February 6th, 2013 01:12 PM #5325
Just monitor the coolant reservoir when the engine is still cold (not yet started) in the morning. Level should be near "high or full" line. Even then the level will not go down significantly. If there is a need to fill up everyday then its a sign of leakage in the system.
Note: Coolant level goes up after the vehicle has been started up and used.even on short trips.
Only use the pink colored coolant for top up. Don't top up with water as this dilutes the coolant.
February 6th, 2013 01:14 PM #5326
February 6th, 2013 01:35 PM #5327
- Oct 2012
- 8
February 6th, 2013 02:17 PM #5329
February 6th, 2013 02:22 PM #5330
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
