Page 132 of 662 FirstFirst ... 3282122128129130131132133134135136142182232 ... LastLast
Results 2,621 to 2,640 of 13229
    Feb 2005
    #2621
    Sad to hear that..
    FOr me everytime i use my Innova, one click lang start na ang sakin, No hard starting whatever...
    So who else with D4D suffer this same syndrome???
    WBR,
    Dec 2003
    #2622
    havent experience hard starting yet, 1.5k kms
    Feb 2005
    #2623
    Quote Originally Posted by accs
    sir share ko lang .. napansin ko pag nag load up ako ng diesel sa shell and total e mas maingay ( yung diesel knock ) SOUND pag nag hard acceleration ako compared to Petron na mas tahimik same power din naman naramdaman ko....
    DIdn't notice this naman on my D4D coz when i'm inside the cabin, very quiet pa rin ang engine D4D ko...I always load ONLY Shell Diesoline Ultra everytime and all the time... Ayaw ko kasi ng papalit palit ng fuel brands... Nung bago pa lang ride ko straight Petron Diesel Max ako after maybe 2 mos switch na to Shell Diesel Ultra untiol now....
    WBR,
    Aug 2005
    #2624
    ATTN: SIR INNOVA BOY
    Please approve my membership sa Yahoo groups -thanks!
    Feb 2005
    #2625
    Welcome to the club pugee!!!
    keep posting bout our favorite Innova van...
    WBR,
    Apr 2005
    #2626
    my D4D G matic logged 5600KMS.. so far one click ang cold start niya.. power is still adequate.. 160km/h kaya niya. been using petron diesel most of my fill ups.. sometimes Shell or caltex pag di available.. haven't tried bio or bio blend yet.. I get 7 to 8Km/l city traffic.. 13KM/L hi way.. so far so good..
    change the headunit to a pioneer. installed a cheap subwoofer, had leatherette seatcovers and full floor matt . my next target would be custom fender and side flares plus eventually 16 or 17 inch wheels.. anu kaya ang maganda na design.. hmmm..
    May 2005
    #2627
    How many members of Innova club has Diesel engine? I think not more than 20 and yet there's 3 of us have this problem wd our diesel engine. I remember one dont start at all and has to replace the whole CRDi parts.Toyota Balintawak Service advisor says im #15 with this kind of problem Hard/Failed starting Fuel pump ang problem daw and not the fuel we use. May 1 Fortuner owner wd this problem din. This only proves that Innova with D4D engine is really a lemon car. Kaya pala ang dami ng resale. I should have wait atleast a year to see if Innova diesel is relly good.What if my warranty expires i have to replace my fuel pump every 5000km. Im sorry guys but i have to say this para mabawasan ang victim ng Innova D4d. If you want to buy Innova buy gas variant nalang or better not to buy Innova at all.
    Feb 2005
    #2628
    *larshell,
    are you sure fuel pump is the culprit with your ride??? nothing else as per your service advisor... just let me know of any developments.. Thanks..
    WBR,
    Feb 2005
    #2629
    Maybe if other also has same problems please post it here so we can compare notes with other the same problem.. and at the same time try to iron out the source of this problems...
    WBR,
    Aug 2003
    #2630
    I experienced the choking problem. I have answered Lord over at the biodiesel Rulez thread, also at the D4D problem thread. With mine, it was a loose fuel filter, although I really thought it had something to do with biodiesel use.
    I talked with my service advisor. We both agree that if it is the fuel pump na nasira, whether the engine is cold or hot, it doesn't matter, palyado or that choking problem will occur. He concurs that with a loose fuel filter, during cold start, the excess air will not allow your engine to have proper fuel air mix, forcing you to rev the engine to compensate and circulate the fuel faster. Once the fuel has circulated, the excess air would be partly or fully offsetted, thus allowing for a more normal sounding idling level. That's why in my case, tightening the fuel filter to prevent excess air into the system was the solution. During their check up, they didn't notice the choking problem although the unit was there for 3 nights, so they didn't suspect any problem with the fuel pump.
    Jun 2005
    #2631
    *larshell : did I understand it right - the problem is with the main fuel pump and not the injector pump - is this correct? Isn't it that the fuel pump is integrated inside the fuel tank and sends fuel from the fuel tank to the engine; whereas the injector pump is located next to the throttle body and pressurizes the commonrail to 1,350 bars of pressure for feeding into the solenoid injectors . . . . . isn't this correct? (not unless unitized yung fuel delivery and pressurization system into one unit).
    So, if this is the case, the problem isn't that serious since the fuel pump is not part of the D4D CRDI system. What is more worrysome is if the problem is with a CRDI component like the injector pump . . . . tama ba ang analysis ko? Tuloy napagisip ako agad sa D4D innova ko na baka lemon rin ito considering #15 ka na sa casa mo with this problem.
    If this is a common problem (add up all the toyota casas with the same fuel pump complaints) e diba dapat mag-issue na ng recall order ang toyota for the defective fuel pump para hindi na tayo maperwisyo. Dapat automatic sa toyota - at 5,000 PMS replace lahat ng fuel pump ng mga D4D. Hihintayin pa ba nila na masira ito one-by-one ?
    May 2005
    #2632
    Quote Originally Posted by Innova_Boy
    *larshell,
    WBR,
    Kakauwi ko lang, kasi pinauwi nila sakin unit ko dahil la stock ng parts 1month to 2months daw ang dating ng parts hustle talaga asar! Supply fuel pump ang problem according to the service advisor.
    Aug 2003
    #2633
    e baka yun yung fuel priming pump connected to the fuel filter or the main pump talaga? Because if it is the fuel priming pump (yung the one you press to bleed the excess air), that's what happened with my kia sedona. Nagasgas sa kakapindot, thus allowing air into the fuel line, causing fuel knock.
    Aug 2003
    #2634
    oops, double post.(edited ko na lang)
    May 2005
    #2635
    *altec, When you tighten your fuel filter does it solve your problem wd hard/fail starting?
    i will try to re tighten my fuel filter.
    Aug 2005
    #2636
    Sad to hear of you guys experiencing trouble with your D4Ds, although I own a gas variant, I too feel sorry about the situation. I think Toyota should recall defective units immediately otherwise baka lumala pa ang mga defects nito.
    Oct 2005
    #2637
    Mga Innova peeps..
    My INNOVA G Diesel Variant was brought by my brother a while ago at Marikina
    Service Station. My 15k PMS was also done at the said service station. Prior
    to
    the 15K PMS, we already have complaints that after several full tanks of
    diesel
    fuel from PETRON and mixing it with ESTROL Biodiesel (5% and 1%), the engine
    begins to experience the following:
    1. The engine often dies after starting it. This is true during cold startup
    (mornings and after several hours of being parked). This is sometimes called
    by
    users - pumapalya o na-chochoke. Kelanagn mo apakan yung gas pedal or rev up.
    the engine.
    2. Sometimes during shifting gears, especially on slow speed (2nd gear) parang
    kakadyot ung makina o malulunod (has the tendency to stop) pag hindi mo agad
    inapakan ung gas pedal.
    3. Sometimes, I feel that the engine is loosing power. Although my top speed
    is
    not affected, the behavior of the engine sa arangkadahan or during normal
    speed
    is not the same. sometimes I do need to drive hard. But I observed that my
    fuel
    consumption is still the same. 9.5-10.5 KM/L pa rin. I am now using Shell
    Diesel.
    All of these symptoms were relayed by my brother sa toyota mechanic sa
    Marikina.
    Toyota diagnosed again our unit by using their laptop to get into the unit's
    engine statistics. My brother also relayed the possibility of the fuel filter
    being clogged and maybe it just need to be adjusted. However, toyota did not
    attempt to take a look. They are satisfied with the results being shown by the
    engine at their laptop. The other bad news is, they still have to report the
    said event either at planta or at Cubao. They instructed my brother that they
    will contact us again for the next visit. This time at cubao. I am planning to
    bring my unit at P. Tamo or Makati this Saturday for a second opinion. These
    stations I believe are independent and have their own pool of expert mechanics
    and management that can decide immediately and do not depend on other
    stations.
    Since I am not the only one who have experienced such behavior, (others are
    just using pure diesel without additives or biodiesel) maybe we could organize
    a body or at least help each other to get the attention of Toyota. I believe
    that the D4d engine is not that bad since it has been released before in other
    countries. There might just be an adjustment with our engines. Lets push
    Toyota
    to work on this issue. Toyota must have a fixed for this issue, better yet
    fixed this issue so that our engine can use and benefit from biodiesel.
    Oct 2005
    #2638
    altec and larshell. san nyo nabili unit nyo?
    #2639
    makukuha ko na uli yung innova g a/t ko na iniwan ko sa toyota quezon ave for repairs (insurance claim) sa bumper.. pinasabay ko na rin ang pagpapakabit ng spoiler... pinapasabay ko rin yung 5,000kms (change oil ) i presume.. but then ang sabi sa akin ng service advisor ay since nung 1,000kms eh synthetic oil ang pinalagay ko... hindi na daw kailangan palitan nitong 5,000.... tama po ba yun?
    nung ranger (ford) kasi ang hawak ko nun.. every 2,500 kms pa nga ako nagpapalit ng langis nun especially nung 1st year.. ngayon lang ako nakarinig na di na kailangan palit langis kasi synthetic...
    pls confirm kung accurate nga ito.. tnx
    Jul 2005
    #2640
    Hi, just want to know if any of you guys know where to buy spare backlights cover in banawe. Any store recommendations? thanks
Toyota Innova Owners & Discussions [ARCHIVED]
