Page 27 of 28 FirstFirst ... 17232425262728 LastLast
Results 521 to 540 of 559
    Jul 2015
    Oct 2013
    #522
    Asan na paps pic nung sayo.
    Jul 2015
    #523
    Quote Originally Posted by vvti2.0 View Post
    I hope this gets thru for the sake na maka contribute ako, not necessary to be done, caveat po.
    Oct 2013
    #524
    Yung bago mo ba na filler cap ay ganyan rin itsura?
    Oct 2013
    #525
    If you will notice sa toyodiy..
    77310A CAP ASSY, FUEL TANK
    77300-28010 (08/2004 - ) 1 $46.54
    77300-52030 (08/2008 - ) 1 $41.99
    OLD tank cap
    Attachment 27760
    NEW tank cap
    Attachment 27761
    OLD tank cap
    Attachment 27760
    NEW tank cap
    Attachment 27761
    Jul 2015
    #526
    Negative bro.
    larger ports na ,pero still negative pressure persist, thus this.
    Have you checked the innova recalls i posted.
    Jul 2015
    #527
    Quote Originally Posted by ericlopez View Post
    Negative bro.
    Last night fter three hour drive, i replaced my diy'd cap with the new one. This morning it (tank) had negative pressure and the popping soiund that goes with it, syet...
    Negative bro.
    Oct 2013
    #528
    Mukhang dapat magpalit ka na rin charcoal canister.
    Jul 2015
    #529
    php 17k charcoal canister
    i guess i have to buy it still.
    thanks , for now diy'd cap muna works no negative pressure, question is will it affect performance?
    #530
    Bro nung ako nagpalit ng charcoal canister eto sagot mo sakin
    If you will ask me, it is the old filler cap lang dapat pinalitan mo.
    Why now you're recommending it?
    [emoji3]
    Oct 2013
    #531
    Eh kasi sabi nya ganun pa rin, malamang di na gumagana charcoal canister nya. Pero if you will ask me, ang trabaho ng charcoal canister at, i feed yung vapor sa balik sa tangke, sa pano magcause yung canister ng vacuum.
    Oct 2013
    #532
    Alam ko 9k lang ang canister. 17k na pala.
    #533
    Oh well i just asked. Pinalitan ko na din naman na.
    Cost me 5K IIRC kaso from abroad binili.
    #534
    I think the function of the charcoal canister is to adsorb the fuel fumes carried by the exiting air and preveNt them from going out into the atmosphere. If the charcoal is blocked, pressures do not equalize and the tank can barrel or pincushion..
    But my question is, whatever happened to the fuel tank breather tubes of old?
    Oct 2013
    #535
    If it absorbs paps and was blocked, ibig sabihin di dapat mag negative pressure.
    #536
    Not really... All it takes is alternating positive pressure and not-so-positive pressure inside the tank, courtesy of a blocked breather..
    All one has to do is prevent inner tank and outer atmosphere pressures from equalizing.. Do it often enough and that tank will deform or spring a leak.
    Consider... Car parked under baking noonday sun.. Tank is heated by sun above and by asphalt below.. Tank vapor pressure goes up.. Some vapor escapes thru semi-blocked breather.. Then driver drives home and parks in cool basement. Tank temp goes down and vapor pressure lowers. Some air manages to go in, but not enough and not fast enough.. Cycle this often enough and one morning, driver finds his tank leaking or distorted..
    Apr 2012
    #537
    Anybody experienced fuel tank problems on their Innova D4Ds? Last Sunday I heard a loud sound emanating from the bottom of my Innova. I looked and found nothing. Now my fuel gauge showed I used 1/8 of my fuel tank just for 40 kms of travel and I saw some splashed fuel underneath my ride on my left rear tire side after I got home. Anyone can help me where to have it repaired outside of the case? My warranty expired just last May 26. I live in Muntinlupa.
    Thanks
    #538
    breather yan
    Jun 2016
    #539
    Hi folks,
    I know almost a year na last post for this issue. Just got a late 09 J gas Innova, got it 2nd hand. What year models are affected? What symptoms to watch out? Thanks
    Sent from my Nexus 4 using Tsikot Forums mobile app
    #540
    My tita called me up, gas tank is leaking again!
    WTF pangatlong gas tank na nila ito hayuf!
    Dinala nanaman sa casa, langya palit gas tank nanaman.
Toyota Innova Gas Tank woes
