1450 kay toyorama.
Just got my cap, not really new, ibinigay ko yung old sa isang kaibigan, pagbalik iba na yung fuel cap ko wahehehee...
Update lang mga paps, nung nagpalit ako ng gas tank cover, yung dating pahigop ng hangin na pressure, naging palabas na sya.
Nung nag pa gas ako sa shell, nag tanung ako sagasoline boy sa experience nila ng pagbukas ng tangke kung san papunta hangin, sabi nila palabas daw talaga.
Hi guys! Just new here and I must admit, I learned a lot from this forum. This is my story...
Mine is 2006 J m/t gas, and at 62K mileage. My innova runs perfectly up until last June 25. While driving at north expressway, I heard something underneath. It was like a stone hit certain metal part. I did not bother to check, stupid me. The following day, before leaving home, I smelled gas and i saw my gas leaking. I immediately concluded, that was the damage done by that stone, or whatever it was.
I called Toyota and believe me, it was a rough argument. I contested that due to the high cost of gas tank (18K, excluding labor), how come it was easily damaged. According to them, it can not be repaired and the only solution was to replace it with a new one. What else can I do? Nganga!!! Hehehe
After a week, when the gas was no longer leaking, I had a mechanic fixed it by putting steel epoxy on that very small crack just beside the strap. I was surprised when I saw the picture posted by nicnoc, that was the same spot where my gas leaks. Wonder how come? In this forum, my case is different since my gas tank was hit. I am now confused and I hope you guys can help me.... Thanks a lot
*jeachaelle,
If it was the same exact position, this is the warping tank syndrome and it was not exactly hit by stone. My first gas tank leak, and my first notion was - it was hit by hard object so I had it replaced using insurance claim, but it happened again after 6 months then I know it was not hit by hard object but a defect in design, because after the first incident and after the first tank replacement, I had a gas tank skid plate protector built by my welder friend to protect the tank from getting hit by hard object, but then still after 6months it happened again. I had my case presented to my dealer, they lifted the car and they saw the skid plate tank cover intact and with the tank warped like it was hit by hard object, this time the dealer replaced my tank, charcoal canister, and filler cap all free of charge.
Steel epoxy would not last long in a week time it would leak again, done that for 3 consecutive weeks heheehBest solution was to have it pulled down by your mechanic and bring it to your suking radiator repair man and have it patched using suplete (torch and lead) and thin sheet of metal to brace the cracked portion. You would not even spend a thousand peso for this including your mechanic labor cost.
Replace also, the charcoal canister and filler cap and these are costly![]()
Thank you, Mile2 for that quick reply. You have been so helpful, as always
So my case is the same as yours? I want to believe that at first. But dear, I really heard that hit for it was quite loud. If you say that it was not caused by the stone, what has triggered that sound? My presumption, if I may say, and correct me if I am wrong, is that, the pressure of the hit made a crack in that most vulnerable portion of the gas tank (my speed was 100kph that time). And there was no warped part anywhere, just a crack about 2 inches.
Of course not, Mile2! I only have it done once. And yes, after 5 days, the leak was back. At least, I made you smileI have not driven my innova for two weeks already. I would love to follow your advise as soon as the leak is gone. Would you believe, if the weather is cold, there is no leak. And each time the sun shines, the leak is back. Grrrrhh!
About the charcoal and filler cap, do I really have to replaced them agad-agad? hehhehe
It is the filler cap that regulates the pressure of the tank, the function of the charcoal canister is to avoid the venting of gasoline into the atmosphere.
Nag warp na yung tank mo habang tumatakbo ka, then dahil sa stress sa bakal nagkabutas na at yung narinig mo na sound ay yung sudden release of pressure at pag balik ng tank sa original shape.
Hi Sio! Thanks again for your quick reply. Di nga? Ganon ba yon? It could happen while driving? Truly? Only the filler cap must be replaced? That would be such a relief. Haaayyyy!
Anyone would dispute Sio? What do you think Mile2? Wow, this is good... battle of the brains, hehehhe
Kailangan mo rin palitan yung gas tank mo, may butas na yan. For the charcoal canister, wag mo na palitan.
It happened lang na nagpalit sila before nung canister kasi di rin pa nila mahanap yung source ng problem, di ko idea yung filler cap, based lang yung sa mga nabasa ko rin sa post ni Mile2 and yung ibang members na nagkaroon ng same problem rin.
Nung di pa ako nagpapalit ng filler cap, kapag binuksan mo yung tanke, pahigop yung pressure, so ibig sabihin may vacuum sa loob, nung nagpalit na ako, yung pressure is palabas.
Sio naman, bakit dapat na palitan yung gas tank? Wada pa ako, hehehe. Sabi ni Mile2, welding lang okey na. Nalito ako ulit, dear. Reply saken kanina ni Mile2, parehas palitan, Tapos ikaw, sabi mo filler cap lang na ang basis mo yung post din ni Mile2. Sana nga yung cap na lang para mas mura ang gastos ko, hehehe. Thank you, Sio!
What model pala ang Innova natin sir? mine is 2005... ano pala ang pinalit mong filler cap yung bagong model or old pa rin?
Ipa repair mo muna ang Gas tank sir then try to change the filler cap first then observed... silip mo gas tank mo kung nag wawarp after driving. kung nag wawarp pa rin then it's time to change the charcoal canister.
Yung bago ng filler cap ang nilagay ko, yung malalaki ang butas, same na with the filler cap of diesel variants.
2008 Innova E.
*kristine123
Hi! Thank you for your reply. Mine is 2006 M/T. Wala pa ako pinapalitan kahit anong major parts. Wala rin ako nadidinig na kahit anong awkward sound, just like what you guys experienced. My innova ran as smoothly as when it was first bought, up until that day when I heard that sound while driving along north expressway.
Girl, sige sundin ko muna advise mo. Yung ginawa mo dun sa filler cap mo, nadali mo ha? Hindi yun nagawa ng ibang guys dito kaya napabilib mo sila, hehehe.
Regarding dun sa warping, sige gawin ko rin yung silip-silip na yan sa ilalim. I hope yung filler cap lang talaga ang problema at hindi yung charcoal canister.
Thanks again, kristine123.
*siopaonatoasted
Hi sio! Sige palitan ko na yung filler cap, tutal 7 years na rin naman. Tignan natin anong sasabihin ng SA ng Toyota pag yung ibang model ang bibilhin ko. Update ko kayo.
Thanks again, sio!
May bagong casualty nanaman pala. welcome jaechaelle.
Yup don't replace your tank, parepair mo na lang.
epoxy won't last. i tried everything that can seal the leak pero wala pa din para ka lang nag band-aid.
