Results 1 to 10 of 17
- 99
August 8th, 2003 02:30 PM #1sorry if may nagpost na regarding this...
guys, sobrang tadtad ng Hilux 4x4. aside from changing the tires, ano pa kaya ang pwede kong gawin to lessen the stiff ride?
meron nagsasabi, baligtadin yung leaf spring, is this safe? may effect ba if i replace the shocks?
August 8th, 2003 02:37 PM #2
Baligtarin mo yung overload spring lang. It's the least used of all the springs unless pang-hakot talaga yung hilux mo. Usually ito yung nasa bottom ng spring pack.
Lower your tire pressure to around 32 psi din.
- 10,620
August 8th, 2003 03:05 PM #3all aftermarket shocks are stiff,
but not harsh.
you could try liquid shocks kaso maalon naman.
August 8th, 2003 05:18 PM #4Originally posted by gjtech
- 99
August 8th, 2003 07:13 PM #6tnx guys...
i know the best way is to change the shocks and springs kaagad, pero what's a good upgrade path on a limited budget?
are there other good alternatives aside from ome?
- 99
August 8th, 2003 07:46 PM #8...and replace it with ome? malaking bagay ba or yung leaf springs muna?
August 8th, 2003 07:59 PM #9
shocks will cost 19200 for the four. springs will cost mga 45k.
you can do what otep said, but it would be a trial and error thing. remove or reverse one spring then observe, till you get the desired ride. sa front you may notice na hindi naka U ang shape ng springs its like an inverted U, i dont know how to do it sa front.
- 99
August 8th, 2003 08:06 PM #10wow expensive pala!
sir arb if i change the shocks muna wud there be a substantial difference or talagang sa leaf spring yun nanggagaling ang harsh na ride?
Daming issue ng SU7:grin:
Xiaomi E-Car
