Page 45 of 53 FirstFirst ... 35414243444546474849 ... LastLast
Results 881 to 900 of 2002
    Oct 2015
    Sino po sa inyo nakapagtry na magpa-align sa CASA? magkano po?
    Apr 2008
    Quote Originally Posted by lexter25 View Post
    I wanted to try but the SA in Toyota Commonwealth told me to just have it done outside since it's much cheaper. Katapat lang ng Toyota Commonwealth ang Yokohama, sabi doon ko nalang daw dalhin, pareho lang daw un.
    *UUE213: I'd choose option A.
    Apr 2012
    Hi, just had my 40k PMS done outside. My driver is the one who brought it to the Bosch Service center near us.
    The problem when i test drove the Commuter kanina.
    I find it hard to shift gears. At ang tigas ng clutch. There's a squeaking sound everytime i step on the clutch. Although audible yon kapag naka off ang engine, so di naman maingay yung squeal talaga.
    Nung chineck ko receipt 4 litres ng Caltex Thuban SAE90 ang ginamit sa pag change ng transmission fluid.
    I checked the manual it says na 75w90 ang required. Ayun ba ang cause ng hard shifting of gears? Kasi pag naka warm up na engine. Medyo smooth na. And also, di kaya overfilled? Manual says 2.6L lang kelangan.
    Sent from my LG-H818 using Tapatalk
    Most likely. With our Toyotas, i observed that the best oil for the transmission was the OEM oil. I could feel the difference when i tried another oil on my Altis before; shifted back to Toyota oil and it was good.
    Apr 2012
    Tama ba sir na 2.6L lang tranny oil? 4L kasi ginamit daw eh. Manual says 2.6L lang.
    Aug 2013
    bro, medyo imposibleng mag overfill. kasi mahihirapang ikabit ng mekaniko yung fill plug. depende na lang kung tinanggal nila transmission at tinagilid para mapuno ng 4L.
    experience ko sa Bosch service center, naka balde yung gear oil, possible na sobra yung estimate ng mekaniko habang nag lalagay siya from dispenser, or 1 gal yung binili ng driver mo bro at nakalimutang kunin yung sobra.
    regarding thuban sae90, ganun talaga siya, magiging smooth lang kapag nasa operating temp na. Maganda Mobil 75W-90, kaso bihira na yung GL-4, karamihan GL-5 na at hindi pwede sa MT (pang rear diff lang)
    Apr 2012
    Quote Originally Posted by innova2013 View Post
    Naka balde daw bro. Pero bubuksan yung bote na tig 1L. Isasaksak yung parang tubo dun. Pero baka nga gnun sa Thuban na oil. Dinrain daw maigi sbe ng driver ko.
    mebbe...
    his tranny got 2.6 li.
    he was made to pay for 4 li.
    Apr 2012
    mebbe...
    4L tlga ginamit. Dinala yung bote pag uwi
    Apr 2012
    Ung isa 1/4 natira
    Ung isa 1/4 natira
    to allay my fears and suspicious, i'd have it checked at another shop.
    May 2007
    Has anyone change to aftermarket shocks/leaf spring/sway bar etc to improve the ride? Kahit puno ng tao yun SG i have this feeling na nasa bangka ako when im inside....
    Quote Originally Posted by akosidags View Post
    Have not tried on ours but I would believe better shocks will help as it had done in our other cars before. If it's like a boat, hindi kaya sira na shocks?
    We've used Old Man Emu, Bilsteins and Iron Man. Old Man Emu was one of the good ones in terms of ride comfort.
    May 2007
    2016 model sir 7tkms on the clock, is there any possibility na may puwedeng higpitan sa suspension sa likod?
    Not much can be done to the stock suspension. What tyre pressure are you running too? We usually put 33psi (cold) in the rear of our Grandia GL. Looks like a shock upgrade would be your best bet
    May 2007
    What shocks would you recommend?
    Mar 2016
    Hi sirs.
    Have also the same problem on my GL, very bumpy ride even with full passengers. Change my shock absorbers (dobinsons) already but not much improvement.
    Apr 2012
    Sino dito nagpa EGR cleaning? How much is it?
    if near Manila area ka lang, Zix can do it for you.
    Apr 2012
    How much kaya at gaano katagal? Nawala na kasi nunber ni zix sa akin.
Toyota Hiace Commuter/GL Grandia/Super Grandia Owners & Discussions Thread [Merged]
