Sir tanung ko lang may abang na wire na ba ang commuter para sa speaker sa rear?
Sir may abang na wire na po ba sa likod ang hiace commuter for rear speakers?
May abang n both sides. Yung sa right side may 2 wire connector na provided. Yung sa left side you need to connect the speaker wire direct dun sa provided na wiring connector (a bit trial and error to find the correct speaker terminals for the left side).
kagabi may nadaanan akong 3 hiace ang involved sa magkakahiwalay na aksidente sa la union at ilocos sur. baka andito kayo sa forum.
Good day po sa inyo any info. Po sa fuel consumption ng hiace commuter with 3.0 engine nakabili po kasi ako 2weeks ago kaya lng as of now kahit anong gawin kong driving habit hanggang 9kl/ per liter lng ang pinamataas ko ang lowest ko naman is 7.5klm/ per liter any suggestion kung paano ko mapapa tipid ung van tnx po
Thank you sir sa response nyo naka first 1k npo ako sana nga mag improve medyo malakas talaga lalo npo pag trapik 6.5klm/ ltr nlng po
Hello everyone! Ask ko lang kung sino na nakapagpa 25k PMS? Ano mga ginagawa dun at how much! Maraming salamat?
Yan na nga siguro yung drawback ng 3.0 engine sa hiace same with the hilux 3.0 mt, their best is around 11 kpl lang considering mas magaan ang pickup. But on the positive side, much better power delivery compare to 2.5 hiace. Just finish the break-in period and see if the economy will improve.
Thank you sir ramones sa info po sabi nga nila ganun ang consumption ang kagandahan lang po sa kanya wala kang bitiin sa takbo at akyat kahit full load of passenger ka.
Went to the dealer today to have that ridiculously deafening, dizzying, mind boggling deep howling/growling sound, that my SG was producing lately which my suspect was due to the AT tires, checked. I couldn't bear it anymore.
They told me that they will do a road test. Before even doing the road test, the mechanic look at the tires and immediately, he knew that it was the tire that was producing that noise. He added that it is really the usual complain of Hiace owners, mainly those fitted with Bridgestone AT tires. The uneven wear on the tread makes a space for the air to enter hence the tire produces a sort of beating sound. I asked if I can rotate but he said, it will still be the same. The only solution is to replace. And the older those tires get, the louder the sound becomes. I can not even think and I don't wanna think how much louder the sound will get for by simply recalling those sounds make me vomit. Since only the 2 front tires have those uneven wear, the mechanic said that those are the ones that I should replace. The rear tires are still even in their wear.
After getting out of the dealership, I immediately went to Yokohama to have those 2 front tires replaced. They too know that those are the problem with those Bridgestone's. They offered me the Yokohoma RY818, same size, 225/70 r15. I got it for 6200/pc via credit card. About 300/pc less if cash.
The difference is night and day! If I only knew about that since day 1 of my acquisition, I would have brought it to the tire shop and replaced those Bridgestone's. I am never looking back. It is so much quieter now, more peaceful, waaaaay less road noise and it's even better than when I rolled it out of the dealership brand new, considering the 2 rear tires are still Bridgestone. I can't wait to replace those 2 remaining the moment they produce noise as well.
Toyota shouldn't put that kind of tire, Bridgestone AT, in the Hiace. It's a people carrier and the last thing that passengers want to hear is the howling/growling sound of tires which makes them deaf and have to shout at each other while talking.
Pic of the tires:
