Hello po mga Bigboddy,
Ask ko lang po SAFE poba magpaconvert ng powersteering or stay on stock manuall steering ang XL ko?
Maraming salamat po sa magrereply?
mga boss, maganda ba ipa sprinter type ung bumper sa likod? maganda rin ba kung pati sa harap? mga magkano aabutin nun? balita ko kasi ilalatero pa yung likod nun para magswak. paadvise sir, salamat!
Mas economical pa din ang EFi kesa sa carb. So i'll go with the 97 gli AT. Saka all power amenities na.
Posted via Tsikot Mobile App
Mga sir another noob question here, ano ba ang advantage and disadvantage on buying a corolla with manual trans vs automatic trans?
May mga friends kasi ako na they keep on suggesting to get manual since efficient daw and mas hindi sirain, may mga facts ba to support those things? Thanks!
there's an entire thread here, dedicated to that exactsame question..
go to it, sir, and see the numerous arguments.
but the bottomline has always been , "it's a personal choice".
my input here is that, MT is mechanically more robust than AT, and in many instances, will outlive the engine. if you want problem-less ownership, the MT can deliver that more easily than AT..
so what does AT deliver? convenience..
^^ sa edad kasi ng oto, may lalabas at lalabas na sira yan. So mas piliin mo ang mas praktikal. Mas praktikal kasi magpaayos ng manual tranny kumpara sa automatic. Kahit sinong mekaniko kaya mag ayos ng manual pero hindi lahat bihasa mag ayos ng matic. Kaya nasabi nila na mas ok ang manual. Pero kung may makukuha kang sariwa na automatic, ok lang naman.
i have a toyota bigbody with a 4efte engine installed and sira po kasi tranny ko and im planning to join a dragrace ano po kayang magandang transmission na pang drag ang pwede ko ilagay sa auto ko?
Hi po mga Master! Need help po on my Corolla, laging nababasa ng langis yung spark plugs nya, madami nag sabi na overhaul no po.. baka may alam kayo na trusted mechanic ng mga corollas natin dito po sa south area.. and magkano po kaya aabutin?? Thanks po!
Good day. Ang 2e engine ko po kumain ng engine oil, ka change oil ko lang kalahati na lng naiwan. Bago rin ako nag palit ng piston ring pero ganon pa rin. Any advice mga boss?
mga sir question lang, yung oto ko kasi parang hindi maayos yung pag sunog ng gasolina, pag aapak ako sa selinyador ko nalulunod xa and hindi maka arangakada ng maayos, hinala ko una sa carb ang prob kasi iba na yung nakakabit sakin eh, ngaun ibinalik ko yung original carb ganun padin and nawawala yung menor, anu po kaya cause nun? salamat
Nagapapalit ka ng carb. Iwasan magka-singaw sa gasket nyan, pakonekta sa intake manifold. Panigurado magloloko ang menor kahit anong adjust mo. Para umayos timpla naman ng gasolina sa sinasabi mo na parang nalulunod sa gas. Adjust mo idle airscrew nya, para matimpla mo yun pasok ng gas at hangin.
Sent from my Starmobile UP+ using Tapatalk
Hello mga sir, bago lang po ako nagpaoverhaul ng 2E engine ko, tanong ko lang normal lang ba magvibrate yung engine kapag magshift ako from 1st to 2nd? Sabi ng shop sakin normal lang daw yun, after 1000km iadjust daw yung timing. Nanginginig talaga yung ato kaya dahan2 lang release ko sa clutch. Tapos yung AC ko d na lumalamig, puro hangin lang. Pero before ako nagpaoverhaul okay pa naman yun, sabi nila my leak daw at lumalabas daw yung prob kapag hindi ginagamit yung auto, totoo ba yun? mga 1 month din sa kanila yung auto ko. 25k po nagastos ko, ok lang po ba yun?
ganyan din 97 corolla ko, nagpa top overhaul ako tas pag paakyat nagvivibrate ung engine, binalik ko sa shop tas sabi nagkamoist lng daw distributor cap ko, ngaun ok na. merun din instance na hinde cya makaakyat nagtry lng ako magpalit ng spark plug, ayun ok n ulit. experience ko naman sa aircon, ganyan din ndi malamig ung hangin, chineck ko ung mga maliliit na hose na nakakabit sa malapit sa carb, tas may nkita ako na natanggal dhil nag cracrack na ung mga hose, kinabit ko at yun ok na din. wla din ako alam sa mga cars, personal experiences ko lng yan.
Nagaalala kasi ako baka fail yung overhaul, tapos di bila akoin na mali sila. Nagdadahilan lang. Di biro ang 25k, at ang tagal pa ng 1000km, seldom used lang auto ko. Abotin ako ng 6 to 8 months non. So baka sabihin nila out of warranty na then excuses again at ako pa sisihin na baka ny ginawa ako kaya nasira.
Magandang araw mga bossing, question lang or any recommendations would do. Ung GLI ko kasi ayaw mag-accelerate ng maayos, automatic siya, pag nasa drive and reverse di kagad nagre-respond, lalo na pag uphill, minsan di na ako umuusad and kahit naka-drive umaatras siya na parang naka-manual which is dapat inde mangyari sa matic. tinanong ko mga may alam sa big body, sabi palitan ko na daw ung transmission ko, pero kaka-rebuild lang nung transmission. Nagpalit na din ako ng ATF, pero inde ung filter. same pa din. di ko naman maibalik sa mekaniko na nagrebuild ng transmission dahil may issue kame hehe. anyway, another recommendation is to change un AT kit and/or ung Mass Air Filter daw. baka daw ung intake ng hangin di maganda kaya ayaw mag-accelerate ng maayos. by the way, once mag-accelerate naman na pag patag ung daan, ok naman na. nagcha-change din ng gear pag sa highway. any suggestion would be appreciated! thank you!
Xe 1993
Help po!!
1. pag start engine nka 1000 rpm po agad same khit open ang aircon
2. Mausok po. Bilis mag bawas langis halos evry 3 wiks dagdag ako
3. Pag ilowered ko xa what po need ko bukod s lowering spring
4. Gsto ko palitan air filter anu mganda thnx godbless
