Results 1 to 7 of 7
- Jan 2011
- 33
January 8th, 2011 10:25 AM #1What's the recommended odo reading for Timing Belt replacement?
How much would it cost in terms of original parts and labor?
How long would it take?
- Feb 2008
- 128
January 8th, 2011 11:00 AM #2pagkakaalam ko ay 80k or 85k odo reading..mine was replaced during that period at toyota alabang..naka more or less 25k pesos yata ako..98 din yung akin A/T..medyo matagal na yun kasi naibenta ko na ang car..pwede ka ring tumawag sa toyota to estimate..pero kung out of warranty ka na siguro try mo pa estimate sa labas siguradong mas mura..
sa akin noon dinala ko umaga nakuha ko hapon..
- Jan 2011
- 33
January 8th, 2011 11:13 AM #3Nasa danger zone na pala, 95k na odo reading eh, maybe its also time for atf fluid replacement....
this is the lovelife model, it this also the baby altis model? i believe AE111 body code ito...
- Feb 2003
- 1,038
January 8th, 2011 12:24 PM #4This post may be totally out of the topic/not specific modelwise but just to give you an idea and ballpark figures...replaced mine though it's a Honda Civic 2005 timing belt*Php1.5+ Belt tensioner*Php6.2K labor *casa Php2.5k...replaced as well the front crankshaft oil seal and front camshaft oil seal thnk for about 1.5K for both seals. a total of around Php12k. The Job itself would just take 2-4hours of wrench time.
*95K km dapat talaga palitan mo na yan ASAP..otherwise lalaki ang gastos mo lalo kapag naputulan ka ng belt...pwdeng wasak ang cylinder head /valve assembly mo kapag minalas kang maputulan ng nsa 3000rpm or hiway cruising.Last edited by Jiggs; January 8th, 2011 at 12:27 PM. Reason: added info
Certified MB Addict
- Apr 2007
- 2,284
January 8th, 2011 03:25 PM #5Kung titignan mo sa owner's manual, nasa 100,000km ang talagang palitan ng timing belt, pero ako pinapalitan ko na pag umabot na ng 80,000km ang tinakbo as a precautionary measure.
- Feb 2008
- 128
January 9th, 2011 10:24 AM #6tawag ka nalang muna sa toyota para matanong mo estimate pag timing belt replacement..diko rin matandaan nga kung nasa 25k kasi masyado mataas yun compared dun sa honda ni jiggs..tapos pa estimate ka rin sa labas para may comparison ka..lovelife din yung akin dati..masama ang loob ko nang binenta ko yun kasi maganda pa manakbo..pinalitan ko ng pick up para di nasayad sa humps dito sa min..
- Jan 2011
- 33
January 16th, 2011 01:08 PM #7Thanks for the info. We did change timing belt, upper & lower oil seals, tensioner bearing, alternator belt, and alternator bearing. less than 5k including labor.
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
