How much ba discount sa Altis ngaun specially the 1.6G variant?
Posted via Tsikot Mobile App
My friend was offered 20k discount. Toyota Pasig has a promo until July 15.
Hi guys,
Unfortunately yung unit ko halos mag 8 days na sa casa dahil may pinapatingin ako na "tok" sound ang problema di nila mahanap ang tunog, binaba na nila shocks at nakailang road test na di padin nila makita so next step daw nila ichecheck ang body at chassis kung may nakausling bakal or what! Hay hasel wala pako sa 5000 km ganun na agad
Ung sakin din may naririnig na din akong rattle sound. Pag nasa uneven road minsan minsan may tunog minsan hindi. Dinala ko saglit sa Servitek para i-angat and matingnan nung kilala naming mekaniko. Wala naman daw problema sa shock. I'll end up pa din sa casa eventually.
Actually madami nga nagrereklamo sa rattling issue. Sakin naman so far so good medyo tahimik sya ang problema k is minsan di ko pa napapatay bumababa nko hahaha (downside of the pushstart )
Anyway regarding sa warranty natin if magupgrade ka ba sounds warranty lang sa audio ang voided or buong electrical warranty na ?
meron din sakin rattling sounds. Have brought this up sa toyota bicutan but I backed out kasi matagal daw magdiagnose ng rattle noise. Mine is coming from the dashboard middle or passenger side. Ang hula ko is yung silver garnish sa dash that's causing the noise. Try niyo katukin, parang medyo maluwag siya.
visited toyota otis a while ago to check the 1.6V, okay naman downside lang sakin is yong seats hindi maganda, anyway bukas pwede ko na makuha agadIt's good to have a SA friend
sadly there are no other seat color options for the V variant as per my SA.
Is it normal for front disc plates to be rust colored?normal naman rear. I hear a kayod sound when I brake and my brakes are mahina compared to my other car
Normal. Mine are usually rust colored after a thorough car wash. Nothing a panic brake downhill won't fix.
brake discs are normally nice and shiny when you get home and park it in the garage. but because the metal surfaces are nice and shiny, oxygen in the air easily reacts with the iron, producing that dull orange compound called rust. by the next morning, the disc surface is covered by a fine layer of rust.
but a few impressions of the brake on your way to work, will remove all that rust.
the process starts over again in your workplace garage..
the process is markedly enhanced with the presence of water. as in today's weather.
bottomline: nothing to worry about.
Sa mga naka v na altis when you press the trunk button of your key bumubukas ba yung trunk niyo mine doesnt seem to open. Yun yung purpose nun right ?
