mine is not an isolated case pala. so i expect that CASA guys say its normal. haha. its not the same with my vios wherein it closes on the weight of the trunk itself.
I also have rattles on the dashboard, front right door, and the rear - i believe its from the sun shade mechanism, its not as solidly built as the Mazda 3.
My running FC is good at 4456Km/397.2li = 11.22Km/L 60% City 40% highway
Check mo yung cover nung lock nung trunk... Usually its a black plastic na cover lang nung lock mechanism... Kadalasan misaligned lang yun... Pwede mo rin sya tanggalin para hindi sya babara
Sent from my Windows Phone 8 using Tapatalk
May lumalabas sa dashboard ECO at cruising speed anu un? Pano alisin?
Posted via Tsikot Mobile App
ECO indicator - pag eco-friendly ka mag drive, iilaw un
Cruising Range ata sir sinasabi mo. Kung gaano pa kalayo ang kaya itakbo, nakabase sa average speed at dami ng gasolina. Pag nag zero ka na, reserve na gamit mo.
Pano tanggalin:
1. Press display hanggang makita un "Settings".
2. Pag sa Settings na, LONG press.
Pansin ko lang din super lamig ng aircon nitong altis lalo na kapag nakaauto. What's the best temperature setting po ba? I had mine at 25 degrees kasi. Then I don't get it why parang same lang ang lamig ng 18 degrees (lowest temp) sa 28 degrees (highest). From my understanding, kung ano yung nakaset na temp, it won't go high above that right? Tapos meron din setting na 'low' kapag pinihit mo pa pababa yung temperature dial, di ko yun gets. ><
Yes ganian nga. 28 degrees is still cold in auto unless you close the vents. i never thought that a super cold aircon will be a problem. haha. i guess one thing is dahil walang heating ang altis. cold lang. on my other experiences with auto climate vehicles with heater, you can feel the cold air blended with hot air at around 26 degrees.
Yes sir, but the fact that the altis has a climate control system means it mixes cold and hot air to give you and maintain your desired temp in the cabin. So for sure may heating capabilities si altis, upon research heated engine coolant yung ginagamit para maglabas ng hot air. Then I read na 'Lo' setting only blows cold air. And is it just me or parang wala naman 'Med' and 'Hi' yung climate control natin which is weird. ><
Just like the Vios, Altis has no Heater. Chilled Air only. obviously that is why it still blow cold air at the highest temperature setting (28 deg) dapat yung highest temp setting which is (Hi) on other ACC pure hot air na lumalabas sa vents. and if you notice the dial, blue lang yung temp control. supposed to be dapat split Blue (counter clockwise) and Red (Clockwise) if it has heating capabilities. Wigo and Mirage Have Heaters. I find it interesting why the altis doesnt have one. though it is not particularly useful in our country
Altis (PHDM)
Altis (India)
Another thing to clarify is yung A/C switch. Is it necessary to leave it 'on' kahit warm weather? Dehumidifier and iwas fog daw kasi ito in cold weathers. My concern kasi is yung impact nito sa fuel consumption and compressor. Haven't tried switching it off yet but sabi sa net di daw tutunog yung compressor kapag naka-off ito which has a bad effect daw sa compressor. Any inputs?
Yan pong A/C switch, thermostat switch. Parang aircon sa bahay, fan at thermostat. Pag naka off, hangin lang ang lalabas, walang lamig, parang electric fan lang. Hindi naman necessary, depende po kung ano gusto nyo.
Depende po ang fog kung saan mas malamig, kung sa loob o labas ng kotse.
Mas tipid nga sa gasolina pag hindi ka naka-on ang A/C. Hindi kasi kumukunsumo ng kuryente ang compressor, patay eh.
Tama nga na hindi tutunog ang compressor, patay eh.
Ngek, hindi nga ginagamit, bakit masisira? Baka nga may dahilan, hindi ko po alam.![]()
Wow I didn't notice that sa dial. Good point sir. Thanks for correcting me. So the ACC only works by adjusting the fan speed only to achieve the desired temperature? Parang nadefeat naman purpose ni climate control since really cant feel the difference whichever temperature you set it. Huhu.
I did. No info on the above fyi. The manual just lacks in details. Mostly generalized.
