Page 146 of 194 FirstFirst ... 4696136142143144145146147148149150156 ... LastLast
Results 2,901 to 2,920 of 5535
    So walang function to unlock the doors when you remove the key from the ignition?
    Wala Jut, but you can activate #4 which unlocks all the doors when you pull the driver side inside door opener within 30 seconds of turning off the engine. If #4 isn't activated, only the driver door unlocks.
    I didn't activate this on mine na because I set it to unlock when I shift to "P" which we normally do before turning off the engine.
    Sa techstream, on off lang itong mga features na ito. Wala ng complicated steps.
    Jul 2015
    Wala ba talagang sound yung door lock and unlock? Di sya pwedeng lagyan kahit yung horn lang?
    Yes. #3 is locking when 25kph is reached. #2 is unlock as soon as you shift into "P". #1 is locking as soon as you move out of "P". #4 is unlocking all the doors at the same time as you unlock the driver side door using the inner door handle within 30s of shutting down the engine. All of these are independent of each other, meaning you can have none to 4 functions active at the same time. But #2 and #4 is redundant on AT because you normally shift to park before ignition off. However, #4 is useful for MT.
    Quote Originally Posted by shok View Post
    I wonder if I can do this with my 10th gen altis.
    Are there other functions I can activate for the 11th gen?
    Not sure with the 10th gen. There are some other customizations for lighting, alarms, a/c and trunk opener modes depending on variant, but you would need Techstream to access all.
    I had to do it so many times before I finally got it.
    Dec 2007
    Did it many times now, even held the lock button for more than 5 secs but di pa rin naactivate.
    I also did the 1 one thosand 2 one thousand then release abruptly and you will hear the locking. Took me several tries til I got the timing. The second time I did it mabilis na.
    Di ko parin magawa tong 5 seconds thing. Pwede bato sa mga v unit and anong mode sa push start ko dapat ilagay? Tried it also while the engine's running still no good. Gumamit na rin ako ng timer for the 5 secs
    Dec 2007
    Will try again.
    ^dapat naka off engine
    Quote Originally Posted by s2kurt View Post
    What Cathy said + Close all doors. Push twice sa start button on V variant without stepping on the brake. Keep shifter in P. Push and hold lock or unlock for 5 seconds. Add another second or two for good measure, then release. It should be at least 5 seconds.
    Apr 2014
    Bigyan na ng award yan si shok for his efforts about the FYIs on our car locking system. Hehe!
    Quote Originally Posted by tevilo View Post
    +1000 Very patient indeed!
    kumusta naman ang fuel consumption nyo po sa 1.6 variant?
    Dec 2007
    Quote Originally Posted by lakay77 View Post
    Averaging 8+ kpl on city driving. Almost 9 kpl for 70/30, city/h-way combination. Fantastic on pure h-way run, which can get me to 18kpl. Jut did a 20kpl.
    Quote Originally Posted by timo07 View Post
    ok na kung ganun. thanks
    Dec 2007
    Yes...[emoji106]
    Yes...[emoji106]
    Salamat. I accept cash. Haha!
    Sayang naman yung features kung hindi magagamit at mapapakinabangan ng fellow 11th gen owners. Convenient kaya.
Toyota Corolla 11th Generation Altis [Merged Threads]
