Results 2,991 to 3,000 of 3575
September 29th, 2017 08:37 AM #2991
- Jul 2017
- 50
September 29th, 2017 09:16 AM #2992curios din po ako dito sir. laging advice sakin ni papang na wag ipapasagad ang gas tuwing full tank. cant ask him why because for sure it will be a loooooooong discussion with him.
hahaha.
so dito ko na lang tanong, bakit po ba mas preferred na automatic fill lan at di yung sagad? sinubukan kong "sagarin" once. at feeling ko mas matagal maubos despite na humigit kumulang 100 pesos lang ang difference.
- 54,271
September 29th, 2017 09:33 AM #2993i don't "automatic fill". i just say, xxxx pesos, po.
if "sagad" means, fill to the brim until it is almost overflowing at the filler tube... na may pa-shake-shake pa, para mawala yung mga bula (heh heh heh)...
....why? marami namang gasulinahan diyan, kapag kailangan nang mag-karga muli..
besides, it might dis-color the paint job because of the overflow.
but this sagad system is the understanding among jeepney drivers. pag-uwi mo sa garahe ang dyip, ay dapat naka-sagad ang gasolina sa filler tube. it's the most reliable way of determining that every driver pays for the fuel he consumed that day.
that 100 pesos is an additional of at least 2 liters or 15-20 km. of course, mas matagal mau-ubos.
- Jul 2017
- 50
September 29th, 2017 04:07 PM #2994sa bagay sir.
kaso minsan kasi sir pag automatic lang ang pa full tank. parang nabibilisan ako sa pag baba nang gas meter.
nakakaparanoid kasi lalo na kung fixed budget lagi ang amount nang pa gas ko. aside po sa presyo nang gas.
ano po kaya ang culprit kaya mabilis mabawasan yung gas ko?aircon?traffic? mejo di na mapuno nang 1000 ang tank e
- 54,271
September 29th, 2017 10:38 PM #2995
October 1st, 2017 09:14 PM #2996
salamat sa pag confirm sa full tank na lumalagpas sa full. First time ko lang kasi makaencounter ng ganun.
Bumili nalang ako original brake pads from toyorama. Costs me 4k and 320 for the labor from goodyear.
Update on my “tok” sound sa steering wheel. It turns out the culprit is rack and pinion. Nagpacheck ako sa wheelers banawe at goodyear sa araneta. They both said it is rack and pinion. Sabi ni goodyear kaya daw repair un. But it would take 2 days and costs around 7-8k. Buying a brand new from toyorama, it would costs around 19.3k and labor costs is 2-2.5k from goodyear and wheeleres respectively. Ok pa naman daw un shock absorber ko. Even the joints are ok.
Pag check lang pala ng joints is gagalawin nila left and right. Kung hindi magalaw that means ok pa. Un suspension, pushed downward lang ang ginawa nung lalaki sa wheelers para malaman un shock absorber. Sabi nya ok naman daw. I was ready to changed my front shocks. For the rack and pinion, palalain ko muna un damage para masulit then saka ko na palitan ng bago.
October 1st, 2017 09:17 PM #2997
Another question, un fan ba ng aircon talagang malakas ang tunog? Noticeable sya pag tahimik ang lugar. Hindi na sya marinig kapag may radio na. Pero hindi naman sobrang lakas. Pag pinatay ko aircon nawawala un sound so sure aircon fan un. Is it normal or dahil matagal na un car kaya ganun?
- 54,271
October 2nd, 2017 12:51 AM #2998
October 2nd, 2017 01:36 AM #2999
Only when I just opened the AC and it's hot (I use auto climate). Once the temperature is stable (fan is 1 bar at 24 C), my car is silent. Several times when I was stuck in traffic, I thought the engine wasn't running anymore
- Jul 2017
- 50
October 2nd, 2017 10:21 AM #3000
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
