Results 1 to 10 of 3575
    May 2011
    Quote Originally Posted by 1D4LV View Post
    see the service records if the shocks and the suspension components have been replaced and have them checked.
    also have the tranny fluid, the coolant and the brake fluids replaced.
    Noted on those. Would it be best to use Toyota Oil for the engine and the tranny? Any recos?
    Compared to my old '97 Honda Civic which, does the Altis still come with a timing belt or is it a chain already? Been confused from what I've been reading so far.
    Quote Originally Posted by mpbtejada View Post
    you may use any oil.... i personally use shell semi-synthetic that i change every 5k kms. same with the tranny oil as long as the specs are the same as the user's manual.
    it comes with a chain.
    May 2011
    Just to clarify. Transmission oil should also be changed for manual tranny? I thought this only applied to A/T?
    Manuals have transmission fluid as well. Cars even have different kinds of fluid for the manuals and autos.
    May 2011
    Quote Originally Posted by mda View Post
    Yup I'm aware of that. It's just that most mechanics I've come across so far would say that "lifetime" daw gear oil for manual tranny. Anyways, I agree that it's a good suggestion to change it as well since I'm starting fresh. Thanks guys.
    i suppose that's correct..
    when the transmission goes awry, then its lifetime is over.
    but sa totoo lang... magkano ba naman ang change trans oil ng MT? give your manual transmission a treat... change its oil at least twice during the life of the car..
    Dont believe those lifetime oils. Better to just replace every 40,000kms at the least.
    On brake pads, OEM Toyota will cost around 3K, Bendix CTs around 900+. If you can afford the Toyotas, go for them.
    May 2011
    Copy that. Thanks Sir!
Toyota Corolla 10th Generation Altis Owners [continued]
