sir shadow diko papo napasok sa casa, bukas palang, ill going their tom as early as posible pag na tignan na nila at parang tatagal, i might return it nalang some other day... my sons birthday is far more important na car namin.... thou medyo naiirita lang ako know may sira si vanzy lalu na at two month palang....................... thanks for the concern sir...
kung fuse yan pababayaran sayo.. mura lang naman.. consumable daw kasi yan.. hindi covered nang warranty..
Kung ang fuse ang dahilan bakit madaling masunog,
nearest possible reason is swicthing-on habit.
Biglang On sa Maximum...
Over sudden stress ang fuse...
Hope aside sa fuse, sana loose connection lang ang problema.
And yes, covered yan sa warranty either minor and of course major, unless kung aksidente na may nabali ka sa knob, etc, but can be covered depende sa 'white lies' mo...![]()
there have been many instances of fuses blowing for no apparent reason. replace them and it's back to normal. no explanations. the map of the fusebox is usually painted on the cover, or in the car manual.
btw, some fuses look ok even if they're not. sometimes the fuse melts near the base terminal, covered by the colored plastic. best way to determine is to use an ohmmeter. or, use substitute fuse (which may blow also! haha!)
loose connections are a pain in the neck, because it may take a lot of work to trace the wires and/or to remove body panels. yes, it's costless, until you give a price to your sore neck and to time spent.
and did you know that suddenly turning on electric motors and incandescent bulbs from zero to maximum, allows momentarily twice the rated current thru it?
lastly, don't buy fuses in the casa. you might get blown by the cost. buy them elsewhere.
good luck.
Sir may nakita po ako dito sa thread yung paggawa ng black cover dun sa ibaba ng bumper near sa foglight. Natanggal po kasi yung sakin right side if you are standing in front of Avanza. Pwede po pakipost nung topic na yun. May alam din kayo car accessories shop or toyota casa selling yung black cover na yun sa ibaba ng bumper. Maraming salamat po God bless![]()
walang benta na other shop yan bos, pwede mo yan orderin sa casa pero matanggal yan bago dumating.
Try this DIY using DVD casing for replacement:
Link of Procedure:
http://avanza-davao.co.cc/forum/index.php?topic=20.0
Hope thats Help you...
At last, napinturahan na.
goto:
http://avanza-davao.co.cc/forum/inde....msg107#msg107
Guys, panatanong po. ok po ba yong roof rail na magbutas pa sa roof? I'm planing na magpakabit this weekend sa isang shop dito sa sta rosa. Wla kasi akong mahanap na yong hindi na kailangan magbutas. Please advise naman po.
Thanks in advance.
maraming salamat xda2jojo sa mabilis na reply maasahan talaga tong forum nato sa panahon ng pangangailanagan...tama kayo madami nga sila stock sa parking lot pero not for sale hahaha... isang pang tanong may nabibilhan ba kayo chrome sa door handle at yung chrome nilalagay mahaba near the plate number? nangitim kasi yung sakin pwede ba linisin yun o wala na pagasa?![]()
Pasingit din...
I am not sure with this kung pwede,
Is TOA Clear Lacquer safe for Bosny High Temp Paint?
Sayang kasi kung diko gamitin mga sobra na mga pintura.
*SEAK:
You're welcome bos...
Mariang Pitik, baka yan din mawala....joke!
Kilangan yan screw na talaga.
