Sir, paano po mag palit ng bulb sa aircon panel? Thanks
Sent from my SM-A505GN using Tapatalk
Sino po nakapagtry magpaayos ng rear aircon vent na malapit sa control knob? Mahina kasi buga compared sa gitna. Thanks!
mga mams at sirs, may alam po kyu mabibilhan ng UltraRacing na Rear Sway Bar? meron na po kasi ako strut bar. puro overseas po kasi nakikita ko, wala ako mahanap distributor dito sa pinas. TY!
Sent from my ASUS_X01BDA using Tapatalk
Boss, Saan po kaya pwede mag pa chek ng radiator fan ng avanza, ayaw kasi ma off, thanks
Jemson's Auto Electrical and Jorge's Radiator Shop
Agahan mo lang dyan boss, lagi mahaba pila dyan.
sa mga naka 195/65/r15 tires, kakasya po ba yun sa lalagyan ng reserba natin? 3rd gen avanza po gamit ko. stock rim ang balak ko lagyan. thanks.
Sino pong taga south ( Calamba or nearby places ) na nag sagad Lowered na sa Gen1 Avanza nila? Also yung nakapag pa Port and Polish na ng intake with Full exhaust and ECU tune.
Sent from my LGM-G600L using Tapatalk
Meron ako question about sa stock rims ng avanza ko. I've been having problems with one of my tires. Seems na.dedeflate sya for unknown reasons. I tried bringing the tire to check for holes pero Wala man. I even tried buying a new tire. But the problem persists. Siguro sa stock rim ang problema? And ano kaya pwede gawin? Thanks po sa sasagot
Sent from my HD1913 using Tapatalk
if the tire really has no leak, and i assume it does not, because it is new:
1. yung inflator valve or "pito". either the one-way valve doesn't sit well, or there is a very small leak around the base of the pito. sometimes, the leak does not show itself unless the valve is manipulated side to side. replacement is cheap. depende na lang ang presyo sa shop.
2. your tire does not sit airtight on the rim. kalawang around the edges of the rim..?
3. your rim has a crack!
tell the tire guy that you are sure you have a leak, because your tire got soft several times already. imposibleng walang leak yan.
good luck.
Good Day po! Una sa lahat sorry sa ot. Nag try kasi akong gamitin yung search function through thread and forum and i'm not getting good results. Gusto ko sanang e-skip yung treads/pages for using the search function to save some time(urgent info), for example i'm searching for topics inside this forum na relevant sa air filter ng avnaza? this questions might have been answered before many times pero natabunan na sa dami ng page. meron bang work around for this? tia![]()
boss, anu pong air filter? yung sa makina or sa loob ng sasakyan? (cabin air filter).
kung sa makita, meron mga sellers dito sa group yung reusable (or washable). pero kailangan maingat ka sa maintenance nung mga yun. or pinaka madali, bili ka nung OEM sa Casa, mura lang naman.
sa cabin air filter, wag ka bumili sa casa, kasi napaka MAHAL. pwede na yung mabibili mo sa lazada, makikita mo naman mga comments nung recent buyers kung pasok or sukat sa cabin space para sa filter. better buy yung may "charcoal", yun gamit ko ngayon, nakaka sala talaga sya ng matinding amoy. hahaha.
mga bossing, payo naman..
i have this plan, pero medyo magastos.. need to upgrade tires, pero mabusisi pala..
currently, i have stock rims, 5jx15 et45. stock tires din 185/65/r15 88s.
I have 2 targets:
1. taller side wall
2. better load rating
as per researching, di advisable ang 195/65/r15 (91H better load rating) tires sa 5inch stock mags, masikip na or pwede mag cause ng uneven wear. not to mention, maiiba ang speedo reading, saka baka may effect din yung medyo mas malaki gulong sa fuel economy at gearing ratio?
if magpapalit ako ng bigger mags, mas liliit naman side wall height (which defeats target1)
then, i found two solutions:
1. buy a 185/65/r15 (92H or 92T tires) na wala ako mahanap sa pinas, pero meron sa abroad
2. buy 14" stock mags ni Avanza (to retain the same offset=45) then install ng 185/70/r14 92H rated tires (made in China)
baka meron kayo ibang solutions... salamat sa payo!
Mga boss I recently had a problem with my car again. Avanza 2011 manual. Seems di na gumagana ung low beam headlights ko. Although gumagana pa ung high beam. I checked the fuses, okay man sila lahat, i even tried replacing them all even the head relay fuse sa engine box.
Is it the bulb? Though gumagana man ung high beam. I tried self fixing to minimize costs. Any advice would be appreciated.
Last edited by avidangler; February 21st, 2020 at 06:24 PM. Reason: Incomplete sentence
So kelangan ko rin tlaga mag replace ng bulb? Ill try to replace din. Kita ko kasi sa Google and YouTube, if may ganun cases. Ung relay ang prob. Hehe thanks
Yun pa rin di ko na check. Hehe, pero may fuse light involvement ba dun? . I tried researching pero more on inside ung involvement nya.
