anyone here na nagpalagay ng armrest with the same color as of our handbrake? pics naman kung merun.
eto lang talaga pinaka draw back sa avanza. ok na ako sa lahat except armrest.
Ok lang dapat ito. The battery is recognized as a separate component and is warrantied by the battery manufacturer (not Toyota). Yung mga stock battery ng brand new units nila paiba-iba din ng brand kumporme kung sino ang supplier nila ng time na iyon.1. Meron ba warranty na mabo-void if papalitan ko battery? Kasi hindi naman maintenance free stock ng avanza natin eh. Yung other car ko kasi has a brand new maintenance free Motolite battery and balak ko pagpalitin. Satisfied kasi ako sa maintenance free kasi my previous same motolite battery lasted for 4 years! Di ba sulit na sulit?
Tama ito. A friend of mine thought that 'distilled water' was battery acid! Buti na lang nagtanong muna. Kaya I use the term 'distilled drinking water' nowadays.What I have learned was to use distilled water either absolute or wilkins
I agree. It was a misconception before.
BTW, there will be no worry if you like to change the battery. Nothing will be void because the battery at present in our avanza has a 1 year warranty only. Why not after one year tsaka muna palitan. That's my plan too to change battery after 1 year lalo na at A/T yung Avanza ko.
Nakuha na ng wife ko yung OR/CR from LTO. Pero wala pa rin plaka. sabi nung SA me issue daw ngayon sa LTO regarding sa bidding ng supplier ng mga plaka. Tanong ko lang kung ok lang ba ibiyahe kung OR/CR lang?
[SIZE=3]H E L P !!!!![/SIZE]
I need your help with this fellow tsikoteers...
Pagpapalitin sana battery ng 2 cars namin(Avanza and Corolla), yung nasa corolla kasi is Motolite Maintenance Free. Pero ng makita ng mekaniko na magkaiba ang terminal, he suggest na papalitan terminal ng avanza. So my wife stopped him, she told the mechanic na ibalik na lang yung stock battery ng avanza. Ibinalik naman nya, BUT the problem goes there na. Nagkadikit DAW yung terminal and it sparked ng saglit. Ikinabit nya na sa tamang terminals after that. Then my wife thought it was OK naman as nothing happen naman after it. Nag-start naman, but when they reached the parking in the mall and she's to activate the security system. She found out na ayaw mag-OFF ng ilaw sa loob pag naka-"door" function. And also, ayaw mag-activate yung remote.
Tanong......Ano kaya problema nito? And may nadamage kaya sa electricals nito?
Dadalhin bukas ng wife ko sa casa. She will say that she found out that the terminal is loose so she tightened it then nagkaganun na.
Help naman guys ......di mapakali misis ko eh. Wala kasi ako sa pinas kaya sya ang nag-aasikaso. Sarado pa naman casa today.....![]()
Mas mabuti siguro sabihin na lang ng wife mo na napansin na lang niyang ganun (may diperensya) yung sasakyan. Huwag na niyang ikwentong may ginalaw pa siya or anything. Just go to the dealer and say the car is doing wierd things. Less talk, less problems. Hindi naman iisipin ng dealer na may ginalaw siya sa sasakyan since she is a female.
Re: nagdikit ang terminal. Gaano kahaba ba ang wires ng battery ng Avanza para magkadikit sila? Saka kung terminal sa terminal lang ang nagkadikit without one being connected to the battery, wala dapat mangyari. Kung nakakakonekta na sa battery yung isang terminal tapos nadikit pa yung isa sa kanya mag spark talaga yun. But even then, nothing serious should really happen. Ginagawa namin iyan sa mga sasakyan minsan just to check if the battery has juice in it.
Saka kapag kinakabit ang terminal sa battery, even if it is the correct terminal, talagang may spark minsan. Confirm muna what the wifey meant by 'nagdikit'.
Thanks a lot OTEP...
My wife just send me a message about sa "nagkadikit".....
Bale lumalabas, naidikit nung mekaniko at first sa maling terminal kaya nag-spark...then he put it to the correct terminal na. Kung baga, nadikit nya sa positive yung negative at first......
All is working well naman except the remote and indoor light is always open kahit naka-lock na lahat pag nasa "Door' mode.
Wala naman ba kayang nasira dito? Naalis lang kaya nag setting ng remote?
Thanks again.
Guys, update ko lang mga available accessories.
Tail-light Extender
judell74,
Napansin ko may sticker na ang plate mo. For 2007-2009 ba ito or 2006-2008? Registered ako for 2007-2009 pero wala pa akong sticker. Thanks!
mukhang promising ata ang avanza a... 1.5vvti lang, di d4d, kahit 2.0 man lang... ok yang tail-light extender, avail na ba yan locally?
nga pala, wala bang 1.5G na avanza na may manual tranny? magkano na srp ng 1.5G?
My wife just checked.....ok naman daw headlight, signal light and busina. Pati din nga pala power window, power lock and power mirror ok din naman daw. It all works naman daw lahat nung electrical things....
Ang hindi lang daw talaga gumagana now is yung stereo, keyless entry and yung ilaw sa cabin laging naka-on pag naka-door mode. So she has to put it sa OFF mode para lang mai-off.
Sana nga yung fuse lang, bukas dadalhin nya sa casa.
Given those situation now mga experts...do you think sa fuse or relay of those(stereo ang keyless entry) lang ang problema nun. Kawawa naman wife ko......![]()
