Results 13,161 to 13,170 of 14970
November 5th, 2009 11:38 PM #13161
sir nimbus
if i am not mistaken the thread mentioned that "if just started", normal lang na mataas (more than 1000). but when it reaches its normal operating temp (Oil Characteistic), it goes below 1000. pag mataas pa rin ang idle mo pag maiinit na makina (usually oil temp indicates half of the indicator), may problema ka sa idle speed. Matalino na kasi ang fuel/oil system natin (VVT-i). You ma refer to CASA na if that is the case. HTH
(Sa wakas nakapasok din ako sa thread. BTW hindi po na apektuhan si vanzie during the recent calamities. Tried to use kennon going up last time. Not advisable. instead, Take Marcos Hiway in going up to Baguio. Chances are you wont notice the 25-meter road cut)
November 5th, 2009 11:40 PM #13162
sir nimbus
if i am not mistaken the thread mentioned that "if just started", normal lang na mataas (more than 1000). but when it reaches its normal operating temp (Oil Characteistic), it goes below 1000. pag mataas pa rin ang idle mo pag maiinit na makina (usually oil temp indicates half of the indicator), may problema ka sa idle speed. Matalino na kasi ang fuel/oil system natin (VVT-i). You may refer to CASA na if that is the case. HTH
November 6th, 2009 02:38 AM #13163
* ma'm nimbus2000:
kumusta ma'm? recheck ko tommorow ang avanza ko kung exactly same lang ba tayo.
November 6th, 2009 08:16 AM #13164
November 6th, 2009 08:43 AM #13165
As long as bagong start ang makina at hindi pa naaabot ang optimal water temp. mataas talaga ang idling at more than 1,000 RPM. Once na reach na, bababa to less than 1,000 rpm.
If I am not mistaken, kahat ng kotse na may computer ay ganito ang behavior.
BTW, pag start ng makina, hindi ko na hinihintay matapos ang warm up period na ito. Alis na kaagad. Iyun lang nga, hindi muna hataw para may time na uminit ang makina at ang oil. Best performance ng oil ay pag na reach na ang operating temp.
November 6th, 2009 10:27 AM #13166
Confirm mo ulit try mo after usage, idle mo engine, coolant temp mo somewhere 30% to 45%, wag mo pihitin steering wheel, dapat below 1000 rpm lang yan, try mo din patayin A/C kung magbago rpm. Kung ganon padin ganito gawin mo dalin mo nalang sa casa mas alam nila yan
November 6th, 2009 03:13 PM #13167
* ma'm nimbus2000:
Mine,
1100~1300 Initial start
900~1000 After 5~10seconds
600~750 Settled
No AC on, Front wheel * Straight position.
We have the same car but mine is with 3k6 mileage.
November 7th, 2009 10:29 AM #13168
* avanza84, xda2jojo, woohoo, meledson, shadow:
thanks sa inyong lahatcheck ko mamaya yung sa car ko. try ko lahat ng sinabi niyo, then post ko ulit dito. napansin ko kasi yung sa sasakyan ng officemate ko, mabilis bumaba yung rpm nya pagkastart, pero strada yung sa kanya. sakin kasi, parang di bumababa ng ganun kabilis, pero nakaON agad ang A/C
[COLOR="rgb(46, 139, 87)"]* xda2jojo:[/COLOR]
ok naman, still overwhelmed with our new rideso far so good. 300 km na lang then punta na kami sa casa for the 1st check up
thanks and more power sa lahat
- Jul 2009
- 27
November 7th, 2009 05:10 PM #13169good pm po, ask ko lng po yung sa odometer ko palaging naka ilaw ang air bag ko, what could be the possible problem? nalubog kc avanza ko sa baha, thanks po!
November 7th, 2009 07:48 PM #13170
Thread was made nung 2018 pa po sir.
