Results 12,051 to 12,060 of 14970
- Dec 2008
- 71
February 17th, 2009 03:04 PM #12051The drag factor is agreeable due to avanza's height.
And, matipid nga yata lalo ang front wheel drive (FWD) kesa RWD. Not mainly because of electric power distribution or weight of vehicle.
Consider this. It seems that more power is exerted in pushing than in pulling. Like in moving a cart or a thing to a far distance. One would rather pull it rather than push to move it.
Corelating then. FWD seems to have the pull system since power is infront. RWD seems to have the push system since power comes from the rear.
If the above is not the true, then can we dream that avanza can do a 22km/li like a vios does? If true, might as well be contented with the 13 to 15km/li fc or so.
Sharing thoughts lang po.
- Dec 2008
- 71
February 18th, 2009 04:10 PM #12052It pays to backread if you have an avanza. Dami matutunan.
Eto iyong answer sa one query ko. Malaking tulong itong rear step bar lalo na pagmeron ikakarga sa likod or if gusto mo ng fx type seating arragement sa third row. And protection din siguro sa kaskaserong tricycle drivers.
Maasahan kaya ito? Ano problems na pwede maencounter pag meron ganito avanza?
Salamat po.
February 18th, 2009 04:23 PM #12053
Maaasahan? Definitely!
Burjegol already said so ("which helped a lot ng ma-rear end siya ng motorsiklo").
Problems? Only when cleaning the portions "covered" by the installed bullbar. Siyempre it will be harder to reach those areas. Lalo na siguro kung yung fiberglass/plastic bumper overriders na halos dikit na sa body.
February 18th, 2009 05:12 PM #12054
disadvantaga ay baka paglaruan ng mga bata at sakyan. Pag nakapark sa labas ng garahe, gawain upuan o patungan ng paa ng mga tambay.
Pero, malaking advantage talaga ay ang protection ng bumper.
February 18th, 2009 07:22 PM #12055
tsaka di yata malalagyan nang backing up sensor yan.. di gagana..
February 19th, 2009 03:38 PM #12056
February 19th, 2009 03:58 PM #12057
I'd sacrifice a little FC for peace of mind regarding the safety of my 3rd row passengers.
For me, pang-newbie driver lang ang mga backing sensors na iyan. Paano kung nasanay ka na, dependent ka na sa mga sensor na iyan, tapos, one day ay bumigay siya't hindi na pala umaandar? Tuliro ka ngayon sa pag-atras, di ba? Pero kung di ka dependent sa mga sensors na iyan, kampante ka pa rin sa pag-atras.
My 2 cents worth lang po...
February 19th, 2009 04:41 PM #12058
magkano kaya score ni sir burjegol nito? meron kaya nung stainless pipe na diretso lang kahit walang step? and saang shops available?
- Dec 2008
- 71
February 20th, 2009 01:16 PM #12059Dito sa link na ito sir meron rear bar and back up sensor at the same time.
http://www.fittmarketing.com/product...ID=164&sID=319
http.fittmarketing.com. Under products, then...4x4 subcategory.
Bahala na kayo mag-upload dito. Di ko alam e sirs.
hth.
February 20th, 2009 01:27 PM #12060
hindi ba ma de detect nang sensor yung rear bar na yun?? eh di tutunog nang tutunog yun..
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
