Results 1 to 5 of 5
    Aug 2011
    guys,
    ask lang ako ng advise to all, plan ko na kasing palitan ang timing belt ng 2004 altis matic ko, kilometer reading is 70000 na
    . . . aside sa timing belt na papalitan ano pa ang mga dapat na palitan or isabay
    . . . may shops ba kayong recommended where to buy ng timing belt and etc. pero yung medyo reasonable price at nagi install na rin
    . . . im from quezon city
    hope you can help me guys . . .
    Feb 2009
    Quote Originally Posted by bartu View Post
    guys,
    as a standard procedure of any conscientious technician, you have to replace the might as well parts (MAW) since the front of the engine is already accessible, i.e.: timing belt, camshaft seal, front crankshaft seal, water pump (if timing belt driven), oil pump seal (where applicable), timing belt tensioner and idler where applicable and wash the affected area of old timing belt dust and foreign debris.
    The Altis has no timing belt; it utilizes a timing chain which doesnt need replacement as long as its not making noise and you follow the change oil schedule routinely.
    70,000kms is just regular change oil, tune-up and clean/adjust brakes. 80,000kms ang madugo (change all fluids, filters, etc.).
    My Altis is also at 70,000kms... but its an 07 model
    Jun 2011
    Tama si sir vinj,walang timing belt ang altis.Ung drive belt chka tensioner assy,pwede nang palitan sa 100tkms.
    Quote Originally Posted by pdspd View Post
    Masakit ang serpentine belt tensioner sa bulsa AFAIK. This is changed if your serpentine belt starts making noise and the belt is still in good condition. BTW, if your serpertine belt is still the original or hasnt been changed in the last three to four years, change it as well (Bando brand is good).
timing belt
