Results 1 to 10 of 17
- Dec 2009
- 242
December 25th, 2009 12:40 PM #1When I was driving other A/T toyota altis bago bago pa, I noticed na mag-start sya to move immediately upon release of brake and unti-unti bumibilis. Now I'm driving another car which is toyota altis din but 2003 and I noticed na di sya umaandar agad unless i-gas pedal ko sya. Na-notice ko yun twice, nung naka-steer sa right yung wheel and yung isa nung nasa-malubak na daan. Nung nasa gasoline station kami umandar sya nung ni-release yung break pero noticeably ang bagal. Most of the time kelangan i-gas pedal talaga para mag-accelerate as quick as with other A/T toyota altis I drove. Ano po kaya problem nun?
Isa pa sa down hill pero naka-reverse when I released the break umabante sya slightly so inapakan ko ulit gas pedal para maka-bwelo. Problem po ba yun or normal lng? Is this related to the problem(if it is) I first mentioned?
Salamat po ng marami in advance.
- Dec 2009
- 242
December 26th, 2009 01:39 AM #2I tried to Google this and the closest I could get is to check the transmission fluid. Any idea where is that located in the car so I could check?
December 26th, 2009 01:46 AM #3
There should be a dipstick in the engine bay for AT fluid.
By the way have you also checked the headlight fluid?
December 26th, 2009 05:56 AM #4
December 26th, 2009 08:03 AM #5
:hammer: ano yan? parang ngayon ko lang ata narinig yan ah?
ang hi-ace namin at pajero eh wala akong makita niyan
to answer the TS question, yun A/T fluid dipstick is located sa engine bay which is commonly place behind or near the engine oil dipstick. madali lang naman malaman kung a/t dipstick o engine oil dipstick. engine oil dipstick eh mas malaki ang handle niya and may label na ENGINE on most cars. the other dipstick na makikita mo without label is the A/T fluid dipstick. basta DALAWA lang naman yang dipstick na yan sir.
at about sa problema mo, follow SU's advise. HTH!
December 26th, 2009 08:36 AM #6
Well, he apparently drives a lot yet doesn't even know where to check fluids for the car. Which most likely means he doesn't even check oil and water and brake/clutch fluids. A precursor to disaster if you ask me.
Kaya check na rin nya headlight fluid para at least di sya mamamatayan ng headlight sa gabi kasi naubusan :D
BANNER BANNER BANNER
- Jun 2008
- 1,439
December 26th, 2009 08:47 AM #7
December 26th, 2009 11:00 AM #8
I have two A/T vehicles one is 09 fortuner and the other is 03 x-trail. The fortuner once the brake pedal is released it goes at once but doesn't accelerate you have to step on it. While my x-trail once brake pedal is released it moves forward but not as quick as the fort. If the road is a little inclined it won't move and sometimes it moves backward if the road is a little bit steeper compared to fort it will still move forward speed depends on steepness. Maybe it has something to do with the engine idle speed. Since they are A/T method of engaging the engine to the wheels is via centrifugal force, the higher idle speed the greater force is being transmitted to the wheels, IMO
December 26th, 2009 11:25 AM #9
medyo disappointing itong Sealion 5 No ADAS No 360 camera
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
