Results 1 to 13 of 13
    Oct 2009
    Mga sir saan ba maganda magpapalit ng timing belt? No history ako kung kelan napalitan yung corolla gli ko.
    I heard sa speedyfix magaling daw at maayos gumawa? genuine t-belt at tensioner kaya gamit nila or replacement? Mga magkano kaya kelangan ko i-budget?
    Thanks!
    with all due respect, if you don't know a timing belt from a hickok belt, i suggest sa casa na lang. at least doon, you're sure of original parts and quality of work. at may warranty pa.
    timing belt replacement is one thing i would not scrimp on. unless you trust the mechanic with your life. because you would, in this case. at least, your car's life.
    Oct 2009
    thanks sa reply dr.d. alam ko naman po kung ano ang timing belt. Napakamahal kasi ng presyo sa casa saka hindi ko nakikita on the spot yung ginagawa sa kotse. Though pwede naman daw ako na bumili ng timing belt & tensioner bearing sa toyota na mismo.
    Madami kasi nag rerecommend sa speedyfix na magaling. Anyway, nakapag pa estimate na ako sa speedyfix. Madami pala papalitan hindi lang timing belt & tensioner bearing pati na din water pump, crank oil seal, cam oil seal, 3 other drive belts para isang bukasan na lang din daw all for php10k including labor.
    salamat.
    ganyan po talaga pag timing belt.. pwedeng belt lang palitan mo po para tipid, pero talagang recommended na palitan mo na lahat para isang labor na lang..
    oks po sa speedyfix..
    juz wondering and I might be OFF topic
    when is the necessary time to replace or change the timing belt? does it differ if your car/vehicle is Gas or Diesel?
    where is speedyfix?
    Quote Originally Posted by ajOT View Post
    where is speedyfix?
    bro read your manual para malaman mo, but di naman halos nagkakalayo 75,000 to 90,000km. pero pinakamaganda basahin muna ang manual at naandoon ang mga kasagutan, hanap hanap lang wag puro tanong. peace bro
Shop na maayos magpalit ng Timing Belt?
