Results 1 to 20 of 22
    Jul 2004
    Mga pre,
    My friend is asking kung ano ang ok na ipalit na tires for his toyota innova G 2005 (AT).
    Any recommendations/suggestions and saan ok bilin if you are located sa south area (paranaque/sucat/alabang/BF/las pinas/etc)
    Also, the stock size is 205/65/15. Pwede din bang kabitan ng 215/65/15 ? or 225/65/15?
    Salamat
    215-65R15 should be fine although it might not look too good anymore. You can also try 215/60R15.
    We just use the stock Yokohoma ASPEC on our Innova when w replace; on another unit we used Bridgestone Turanza (this is a quiet tire).
    Aug 2010
    magkano na ang Bridgestone Turanza?
    Jun 2006
    Bought the same stock tires at sonny ok tire supply for 3900.
    Yoko magpalit, baka magbago pa ride.
    Quote Originally Posted by trucker111 View Post
    The last i bought was Yokohoma Aspec. 3.9K each at F.B. Ladao in Timog. DKC quoted me 4.1k on the phone so usually the tawad comes when i go to the store.
    Jul 2004
    By the way, I called up Roadstar alabang and this is their recommendation:
    Size 215/65/15
    Kumho = P3600 each (P14,400 for 4pcs)
    Ok ba kumho? or malaki ang difference ng Yokohama (stock ng innova daw) or Dunlop?
    Oct 2011
    Kumho is okay you might opt to try out GT Radial as well kung namamahalan ka sa stock tire.
    Sep 2011
    imo , mas mainam yung stock na 205, yun kasi ang naka design sa kanya na tires ,kesa mag papalit ka ng ibang size mag babago ang takbo niyan sir
    opinyon ko lang po yun nasa sa inyo parin kung gusto mo pa rin i 215 ;)
    Oct 2011
    The last time i check nasa 4.5k ung AR10 ng bridgestone turanza
    Posted via Tsikot Mobile App
    Stock tires ng innova namim 8 years old na din. Will have to replace it soon na i guess. May Toyo tires kaya na stock size ng innova?
    imho.... if you are using the stock rims, better stick to the stock size.
    Aug 2006
    Been using Indonesian Delium Tires with stock size 205/65R15, so far very satisfied makapal pa rin after a year of abuse :thumbup: dami ko kasing nakikita na Innova sa Binondo area at Divisioria na naka Delium kaya I have tried on my 2 front wheels.
    It has higher speed rating at 94H compared to stock Yokohama Aspec S rating
    Cost per tire - P3K each
    Quote Originally Posted by 1D4LV View Post
    yep im sticking with stock size.
    Quote Originally Posted by Mile2 View Post
    may picture ka sir ng side wall ng groove pattern?
    Aug 2006
    May nakita akong picture sa sulit.
    Maganda sa tire na ito ay yung RIM GUARD :thumbup:
    Actually parehong-pareho siya ng 205/70R15 ng Indonesian Spectra Tires
    Jun 2010
    Freddie's and Wheelhaus on Evangelista street Makati quoted me P4,000 for Bridgestone Turanza AR10, but for 195/65/15 (my Toyota Revo's tire size). I recommend these tires coming from Yokohama ASPEC stock.
    Sent from my COSMOS X2 using Tsikot Forums mobile app
    Jun 2006
    How long does your tires last? Mine lasted only 35k.
    Mabilis daw maubos kasi im using only 30psi which is below the recommend pressure.
    Kaso matagtag pag lagpas 30psi.
    Oct 2013
    I re-purposed my Camry tires and mags into the Innova and I think and feel that the ride has gone better. It also looks nice given the wider dimension of the tires and almost an inch height gain, I think... hope this helps!
    Aug 2004
    Indeed. Some of the "tagtag" for the Innova comes from the tires. The "Sportivo" Innova variant, with wider and lower profile car tires, rides better than the regular Innova.
    Apr 2009
    mga sir pa recommend naman saan pwede maghanap 2nd hand alloy para sa yokohama 205/65/r15 na gulong. bago pa kasi gulong, pero gusto ko mag upgrade ng rims...
Tires for Toyota Innova
