Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Feb 2011
    Mga sir baka may makatulong, pwede ko kaya papalitan ng bago tong unit ko? My unit is a 2014 Fortuner 4x2G Diesel VNT M/T and I got the unit sa Toyota Makati, was released last Sept. 5, 2014. And to tell you po, naibaba na transmission nito agad for warranty sa Toyota Taytay last Nov. 11, 2014, 1,671kms pa lang mileage as of now. May parang kumukulo kase na nararamdaman yung paa ko pag ni rerelease ko clutch pedal. Actually naramdaman ko na sya before pa ko magpa 1k PMS, mga 600 kms. plus mileage pa lang siguro nung unang naramdaman ko. Pinacheck ko sa Toyota Makati nung 1k PMS, normal lang daw so akala ko ganon talaga. Pero i compared it sa other units, walang ganon eh.
    So dinala ko po sa Toyota Taytay last Nov. 11 since yun ang pinaka malapit na dealer sa place ko. Ang findings sa Toyota Taytay after nila ibaba transmission was meron daw pong 8 fingers ang pressure plate, 3 daw po naka angat dun sa 8 fingers. Inalign daw po nila to fix the problem. I got my unit back Nov. 12, 2014. And JUST AFTER 1 DAY, Nov. 13, 2014, nararamdaman ko nanaman yung parang kumukulo pag ni rerelease at inaapakan ko yung clutch pedal which really bothers me. I asked the SA sa Toyota Taytay pano umangat yung fingers ng pressure plate na sinasabe nya, sa pagkagawa daw ng sasakyan, so this is really a factory defect, right?
    I really want my unit to be replaced. What should I do? Napaka aga para ibaba transmission nitong sasakyan and again, nararamdaman ko nanaman yung complain ko. Bumili ako ng brand new na sasakyan tapos ibababa lang kaagad yung transmission. Ayoko na ibaba nanaman yung transmission nito para I-diagnose lang nila yung problem na trial and error sila na gagawin nilang daga tong sasakyan kong worth 1.3m to look for the problem. Feeling ko hindi na brand new yung Fortuner ko, and I dont want this car anymore.
    Can I demand for a unit replacement for this? I just really want a unit replacement or a refund for my Toyota Fortuner.
    Right now, waiting daw po ang Toyota Makati for the response ng Toyota Motor Philippines technical team. But as of now, my decision is that, I will not accept our Fortuner anymore, because I really want the unit to have a replacement
    or a full refund.
    Please help po, Thanks.
    AFAIK, it's not for the unit to be replaced at this point but rather, they should first replace the entire clutch assembly first if that's the cause. What does the Law have to say?
    We had clutch problems on our 2005 Patrol GU and our 1996 LC80 before (when both were still near brand new). Toyota replaced the clutch and release bearing twice before the problem went away for good. Nissan also did the same on the Patrol and they had to replace the clutch master as well before it went away. Both vehicles are still with the family to this day with well over 100K on the odo. No units replaced but the problems were fixed.
    Feb 2011
    Ang akin lang kase sir, ginawa ng Toyota Taytay, then one day lang, isang araw lang, anjan nanaman yung problema, then for sure ibababa nanaman ng Toyota Makati itong transmission. Kung ibababa kaya nila ulit sir, can I request for a whole new transmission system na not just the clutch system?
    I really feel din na ang lakas nya sa diesel talaga, pwede kayang dahil dun sa problem nya?
    Aug 2004
    Your rights under the law are to demand a replacement of the whole vehicle if the problem cannot be fixed after four extra repair attempts after you invoke lemon law coverage. Which means they get three more attempts to fix the problem.
    As for transmission replacement... a bit premature to say. You'll have to wait for the advice of the dealer.
    Jul 2006
    Nakalusot sa Pre-Delivery Inspection ng Toyota Makati yan?
    To think na TMP dealer yan. (AFAIK) Tsk, tsk, tsk.
    What is "kumukulo" na clutch by the way?
    From what I can surmise after reading your story, your clutch is "grabbing". This is because the clutch fingers are not aligned to permit smooth / straight forward engagement of the clutch friction disc. Another term would be clutch judder.
    Demand at the very LEAST, for the dealer to replace your clutch assembly, (clutch disc, cover, and release bearing). It was not "repaired" in the first place.
    My 2 cents worth.
    Feb 2011
    My 2 cents worth.
    Yun nga po yung sinasabe ko sa TMI, na pano nakalusot sa PDI po yung unit na yun tapos binenta pa and TMP pa po ang may ari sa dealership na yun, sobrang bagal po ng response, Friday pa po ako nag complain, then hanggang ngayon, ang sabe lang waitng po daw sila sa sagot ng TMP for the technical team na pumunta sa TMI.
    So sir, if I will be requesting for a clutch assembly replacement (clutch disc, release bearing, clutch cover, pressure plate etc.), and the problem will still persist after fixing, can I demand for a unit replacement/refund after that? Gusto ko po kase sana kung possible is magkaron kame ng agreement, na ganon na after i replace nila ng buo, and babalik yung problema, automatic palit unit na. Kase I really feel po na hindi po tama ito para binayaran ko, this is really frustrating, very inconvenient for us din kase dahil from Angono, Rizal pa po kame and ang layo layo ng Toyota Makati samin.
    Kumukulo sir, like parang I feel na there is a grinding vibration sa clutch pedal na nararamdaman ng paa ko while depressing and releasing the clutch pedal. Parang tama nga po kayo dun sa "clutch judder" dun sa misaligned clutch and broken finger.
    So buong clutch assembly po ang papapalitan ko? Nakaka apekto po ba sa fuel consumption tong problema na ito since ang lakas po ng unit ko sa diesel?
    3 din po kase ang complain ko sa unit ko.
    1. This broken clutch/transmission
    2. There is a "boog" sound sa hood pag napapalakas yung sara ng pinto po sa harap, I tried po na isara ng malakas na malakas yung pinto nung bukas yung hood, wala naman pong tunog.
    3. There is a stain na ayaw matanggal dun sa rear left window ng unit ko and meron din pong chip off paint na tinanggap po ng Toyota Makati na aayusin nila pero di pa po napapaayos sa kanila hanggang ngayon.
    Kaya po I really believe na parang hindi din po maganda ang pagka stock ng unit na ito sa dealership nila talaga eh.
    Quote Originally Posted by ericson21 View Post
    Try to check the hood stopper adjustment.
    Jul 2004
    Ito ang alternatibo mo: For Consumers
    Jun 2011
    May anti-LEMON law na yata tyo d2 sa pinas.pwede mo ilaban kung sakali d pa rin maayos ung sasakyan after replacing the clutch assy(pressure plate,clutch disc,release bearing).pero dapat nung unang ginawa pa lng sa Toyota Taytay,pinalitan na kagad.ung mga fingers na cnasabi eh ung tinatamaan ng release bearing pag tinatapakan ang clutch pedal,tama po ba?so palagay ko,mapalitan lng ng clutch assy yan,oks na yan sir.wala na cguro kinalaman ang tranny para papalitan mo din.address mo kagad sa service manager ng toyota taytay kse warranty claim na,backjob pa.para makuha mo din kagad sasakyan mo the same day.
    Jul 2006
    Hi,
    Yes, demand that the clutch assembly be replaced. Sh!t happens (sorry to be so frank about it), the most probable explanation for this is the clutch cover that was installed into your car had a defect that slipped thru quality control at the manufacturing plant. The parts are not made by Toyota themselves, rather they procure them thru OEM Manufacturers. These parts are made using Toyota specifications, what ever they may be.
    I do not see any problem with the tranny (subjective point of view).
    The other concerns, you can refer to your dealer of choice. Have your Service Advisor write on the service booklet all the things that were done to your car. Also keep copies of the work invoices (kahit under warranty pa yan). These would be your documentation should future problems come out. Wag naman sana. Good luck.
    Malakas talaga sa fuel consumption kasi hindi maganda lapat ng clutch dun sa flywheel kasi hindi lahat ng spring gumagana so nag-sliding clutch ka.
    well, if complete replacement of the clutch assembly doesn't work, the next step is probably complete replacement of the transmission assembly and clutch assembly..
    if that doesn't work, then i guess the entire vehicle has to be replaced..
    Aug 2012
    What the Anti-Lemon Law states
    (philstar.com) | Updated August 1, 2014 - 7:15pm
    MANILA, Philippines - Republic Act No. 10642 or "An Act Strengthening Consumer Protection in the Purchase of Brand New Motor Vehicles" otherwise known as the "Philippine Lemon Law" has finally been signed by President Aquino last month.
    The measure seeks to "promote full protection to the rights of consumers in the sale of motor vehicles against business and trade practices which are deceptive, unfair or otherwise inimical to consumers and the public interest."
    The bill had been pending in Congress for 27 years before it was finally enacted into law.
    The Department of Trade and Industry is drafting the implementing rules and regulations of the law.
    Before the measure is finally implemented, let us take a closer look at it:
    1. The measure covers "brand new motor vehicles purchased in the Philippines reported by a consumer to be in non-conformity with the vehicle's manufacturer or distributor's standards or specification with 12 months from the date of original delivery to the consumer or up to 20,000 kilometers of operation after such delivery, whichever comes first.
    2. However damage that is caused by noncompliance by the consumer of the obligations under the warranty; modifications not authorized by the manufacturer, distributor, authorized dealer or retailer; abuse or neglect of the brand new motor vehicle; and accident or force majeure are excluded.
    3. If the car has been repaired at least four times, by the same manufacturer, distributor, authorized dealer or retailer for the same complaint and the non-conformity issue or problem remains, the consumer may invoke his or her rights under the measure.
    4. To avail of any remedy, the consumer must first notify the manufacture, distributor, authorized dealer or retailer of the unresolved complaints, and the consumer's intention to invoke his or her rights under the Act.
    5. A number of remedies for dispute resolution may be availed of. These include mediation, arbitration, and adjudication.
    6. The manufacturer, distributor, authorized dealer or retailer adjudged to have violated the provisions requiring disclosure as mentioned in the preceding section shall be liable to pay a minimum amount of P100,000 as damages to the aggrieved party without prejudice to any civil or criminal liability they and/or the responsible officer may incur under existing laws.
    Aug 2012
    Full text of Philippine Lemon Law can be found below:
    http://tsikot.com/forums/traffic-law...10642-a-99999/
    Quote Originally Posted by red_one View Post
    so is the anti-lemon law already in full swing, or are we still waiting for the rules and regulations?
    Aug 2012
    Yes, it is in full swing. Meron ng first case vs Audi last month but car already fixed.
    Fledgling Lemon Law will be put to test following complaint by trader vs car dealers
    Audi becomes test case for new Lemon Law | Motioncars
    Audi PH responds to Lemon Law complaint | Motioncars
    Aug 2010
    i guess by now, TS should be looking for a lawyer who can help him write the demand letter... just in case the problem is not solved.
    paiikutin ka lang ng tmp.
    Jul 2006
    I'd like to think that a full replacement of the clutch assembly will solve his present concerns. All things being mechanical in nature. What should be more worrisome, is the psychological effect (short term or otherwise) on the TS as a consumer/buyer/end-user.
    TMP should go the extra mile on cases such as his.
    Aug 2010
    OT
    if TS bought the car in installment, can he stop the monthly payments until the problem is solved?
    Quote Originally Posted by trucker111 View Post
    OT
    he can't because if the car is amortized, the bank already paid the vehicle in full. so kay bangko sya may utang. hahabulin sya ng bangko pag ganyan.
Brand New Toyota Fortuner Diesel M/T Transmission Problem, Needs Unit Replacement
