Page 4 of 4 FirstFirst 1234
Results 61 to 68 of 68
    Sep 2004
    Daily drive ng ppv tapos magisa pa, malamang sa lamang yung vios pa rin ang gagamitin mo after ng honeymoon stage mo dun sa bagong ppv mo.
    Best to base your selection na tutugma sa pinakafrequent use-case mo.
    If ako pipili sa lagay mo, CRV diesel siguro piliin ko.
    Aug 2006
    Quote Originally Posted by L1quid View Post
    +1
    also single driver after a year lagi na lang nakagarahe yun fort ko
    i take my mom's jazz most of the time
    Apr 2008
    I travel alone 90% of the time. I also have never had a daily driver that doesn't have a third row. [emoji23]
    Like the good doctor says, aftermarket can't give you more space. It can, however, give you more speed, better handling, the latest entertainment system...
    I suggest you get the diesel. Even a used diesel, if you're open to used cars.
    Sent from my SM-G900I using Tapatalk
    Jun 2018
    Quote Originally Posted by GTi View Post
    +1 on the diesel. Go fortuner. Rush has the same gasoline fed engine as the avanza. Rush is also heavier than the avanza, so FC will be higher than the avanza.
    Aug 2014
    +1 sa Fortuner, Ground clearance lalo na nag babaha satin. Single driver din, Ako lang din gumagamit ng fortuner ng Mother ko inalis ko na yung third row seat nung pag ka labas ng casa, para lang rav4 at sobrang spacious ng likod [emoji111]️[emoji23]
    Sent from my SM-G950U using Tapatalk
Rush or Fortuner for single?
