Results 1 to 16 of 16
    hi,
    any thoughts on why innova is lower by 10mm on the driver side? i don't think my weight of 170 lbs would impact it that much! take note that the gas tank is just 1/4 full.
    How old is your unit and what is the mileage? Check first the shocks and springs.
    1 month, 3000 km. what in particular do i need to check with shocks and springs?
    can i know the specifics of what and how to check here so that when i get to the dealer, they won't bs me.
    GRABE!!!! 10mm napansin mo pa?
    oo nga sir normal na ata yan kasi 10mm (0.39 inches.) lang naman...
    what do you mean sir kung sa passenger side ka uupo di sya bababa ng 10mm?
    yes, because i clean the wheel well. pag me difference sa sukat ng buka between wheels and fender, ramdam ko agad. then i will measure from a level ground, and the 10mm difference came out.
    Quote Originally Posted by kristine123 View Post
    i don't think it should be normal. vehicles should have a level stance when unladen - bare stock, correct tire size and inflation, all fluids filled, gas tank filled up.
    at this point, that its bare stock, correct tire size, inflation and 1/4" filled gas, the driver side is already lower by 10mm. take note that the gas tank of an innova is on the driver side.
ride height problem in innova
