Results 1 to 10 of 10
    Dec 2002
    Hi peeps,
    Can you recommend any good toyota mechanic which can overhaul or dukot a Toyota 2L Turbo EFI engine. Ito yung makina ng nabili kong Toyota Hilux Surf. Tumatagas na yung langis, nauubusan na ako ng langis every week, about 1 liter per week to be exact. White ang smoke niya minsan so I guess that's because of that problem.
    My only resource for now is DENSO banawe, kasi sila lang yung malakas ang loob gumalaw ng makina ko kasi raw wala pang Electronic Injection Pump calibration dito sa pinas (sabi nila), ATI makati already backed-down kasi di raw sila marunong sa EFI diesel engine. I'm planning to get it fix by early January and I'm canvassing kung saan magaling and sure yung gawa..
    marami pong salamat in advance.
    ebags,
    Akala ko aircon ang problema. Sasabihin ko sana dalhin mo na lang kay mang mar diyan sa Bago Bantay. Hehehe.
    these shops were just recommended by colleagues and friends form the industry although i dont have personal experience having my car tuned or fixed by them
    Toyota hi performance specialists:
    Larry feliciano-lf tuning
    Phil gulfin- tunes toyota formula cars and circuit cars
    You could also try aer machine shop i think they repair engines rin there
    Call Edwin M. 9305734.
    You might also want to consider changing the entire engine if the cost is not too much.
    Dec 2002
    sir freeman,
    sino po si Edwin M? any background info?
    Try mo si Ferdie 360-3268. Kung dukot lang. Hiwalay naman ang engine sa EFI niya. He's my cousin and mechanic. Tell him ni - refer ka ni Alfred.
    Dec 2002
    sir alfred,
    maraming salamat po.
  9. #9
    2L ng Hilux-surf: Bro issue din dyan ang cylinder head. Maraming feedbacks from the Net na nagcra-crack. Check it na rin. Drain the cooling system and change the thermostat controlling the aux fan. Pwede rin direkta mo na dahil mainit naman dito sa atin.
    May 2011
    Quote Originally Posted by Bossing View Post
    bossing may number ka ba ni phil gulfin and larry feliciano?naghahanap kc ako ng magaling mag tuning.salamat.
recommend good toyota mechanic
