Results 1 to 13 of 13
    good day po sirs and maams.. im a newbie driver po and i just want to know more about the overdrive function sa altis.
    kasi nabasa ko po sa manual na pag on siya e nasa fourth gear siya kaya mas matipid sa fuel consumption and pag off e nasa third gear daw.. kaya i assume na yun ang rison kung bakit default sa shift ang "on"..
    anyway, nalilito lang po ako kasi sinearch ko po sa internet yun and i learned na ginagamit lang po ung overdrive pag 70kph and above na speed mo..
    ano po ba talaga?
    thanks for sa mga reply niyo...
    Aug 2005
    Normally leave the overdrive on. may indicator sa dash kung naka off.
    Kapag medyo mabilis na ang takbo mo tapos gusto mo na ma force mag down shift from 4th to 3rd, you can turn the OD off para lumakas ang power. Typically used for overtaking.
    Normally just leave it on. also normally, just place it in "D".
    ok thanks po sir.. mejo baligtad po kasi pagkakaintindi ko dati.. akala ko dapat naka on pag magoovertake kasi nga as the name implies hehe
    anyway thanks po ulit
    Sep 2005
    sir meledson...is it ok to turn it off O/D pag akyatan like kenon road? may nagsabi sa akin mas malakas daw po power ng engine sa akyatan pag off O/D.
    Jan 2009
    Quote Originally Posted by ruelsdcz View Post
    Yup. Turn it off when driving in hilly terrain.
    Aug 2005
    kung mild lang ang terrain, there is no need to turn it off.
    by default, naka set ang A/T for fuel economy.
    So far sa ZZ ko, hindi pa ako nagkaroon ng need to turn OD off. papanik sa parking buildings, naka "D" lang ako.
    ECT is a different subject.
    Instead of turning OD off, why not turn on ECT for a little bit of power.
RE: Overdrive function sa toyota altis
