Results 1 to 12 of 12
    Jul 2012
    Hi Guys,
    Finally I was able to have my first car na, A Toyota Altis 2002 AT 1.6 E.
    Ask lang ako guys kung paano ko ma-check ung Overdrive if ng-ffailed na? Ano ba talaga ung Overdrive?
    Un indicator niya umiilaw naman.
    I would really appreciate your inputs guys.
    Thank you in advance.
    Aug 2004
    Drive it. If it does 2800-3200 at a steady 100 km/h, you're in overdrive. If it does much more, you're not.
    If the OD OFF light is on continuously, then it's off. There's a button on the shifter to toggle it on or off.
    If the o/d is off, your engine has a tendency to engine brake and it doesnt shift to 4th gear (hanggang 3rd lang).
    Jul 2012
    thank you sir's. Can I test the o/d without driving 100-120kmh?
    How about when park?
    Yung L = 1st gear...
    2 = 2nd gear...
    OD off = 3rd gear...
    D = shifts automatically from 1st to 4th gear...
    If you are running at D and at 80 kph, yung rpm reading should be within 2000rpm.
    Now, if you switch to "OD OFF" during this instance...rpm should rev-up to around 2800rpm.
    If that didnt happen...then there's something wrong with your AT.
    Jul 2012
    Quote Originally Posted by admiral88 View Post
    2 = 2nd gear...
    Okay this now make sense to me..
    OD OFF should make me faster without pushing to hard on my gas? am i right?
    thanks guys,.
    Aug 2004
    Quote Originally Posted by anakngsultan View Post
    You can't even get into fourth gear on the Altis without hitting 80 km/h, so... no.
Over drive on Toyota Altis 2002
