Originally Posted by
Lew_Alcindor
It is that time of the year again. I usually have my PMS at 5,000kms which coincides at 6 months since last oil change.
That last time I had my oil change, the odo was at around 15,000kms. I used Toyota Fully Synthetic oil then.
Then I replaced the oil filter with Baldwin B229 (I think) at around 20,000kms using the same fully synthetic oil up to this writing.
For the 25,000kms PMS, I will shift back to mineral oil Delo Gold 15W-40. I want an oil that is easy to find here in LB, Laguna.
Then I will give Baldwin BT223 a try (although I still have one B229 which is longer than the BT model). I am exploring changing my OCI to 4 months. So that will be 3x a year instead of 2. The vehicle usually log 10,000kms per year.
My Innova is suffering from the uneven tire wear at the front. SO I will have camber and caster alignment fixed again.
I'll have my front break pads checked because I hear some squeaking while breaking this morning.
I'll consult the owner's manual to see what needs to be inspected or replaced. I am thinking of the cabin filter and the air filter for the intake.
Change oil - prbably by myself
Camber/caster alignment - Servitek
