Results 1 to 10 of 10
    Hi,
    We are considering buying a second hand 2003 Toyota Vios. Please share any info about the Pros and Cons of this model.
    Tnx
    Jul 2003
    what grade? 1.3L or the 1.5? E or G? ok naman ang vios as a daily driver. matipid and reliable. tingnan mo mileage. pa check mo sa mechanic na rin lahat.
    Aug 2004
    Just check that everything is okay, bring a mechanic along. The mechanical package of the Vios is reliable naman, just make sure that there are no unforseen defects.
    But I think that you can actually get a higher model for not much more than the 1.3 if you want all the extras.
    Aug 2006
    be sure to ask about the fuses and headlights.
    i've heard that Vioses suffer from easily blown fuses in their lamps.
    I assume non warranty na yan since 3 years na... so better check if there are problems.... blown fuses, moist headlights, kabig problem (common if it still have the stock nct5 tires)... Check also PMS if it has... ok na 1.3 perokung 1.5 mas ok! maliit lang ata ang difference sa price for second hand vioses.... gudlak in ur new ride!
    may club ang mga vios owners try to check the site www.viosclubphil.com they will answer most of you question and will help you dress up your vios..
    Quote Originally Posted by gonzo View Post
    Yup. Check out the forums on that board. There are quite a lot of topics on Pros and Cons, and as mentioned by gonzo, a lot of topics on modding your ride
    Oct 2003
    check nyo rin po kung regular yung pms nya sa casa. meron record yan sa casa mismo.
    Dec 2008
    hi,
    how much does a second hand vios usually cost? thanks.
    As long as the previous owner maintained it properly and it wasnt involved in any majore accident and there shouldnt be too much problems IMO.
Need advice on a Vios 2003
