Page 43 of 82 FirstFirst ... 3339404142434445464753 ... LastLast
Results 841 to 860 of 1627
    Sep 2010
    #841
    Hi All,
    I'm planning to buy the 2010 rav4 4w2. Any problems or concern with this suv? thanks
    #842
    VVTi naman yang RAV4 so its fine...
    Sep 2010
    #843
    thanks tidus for the info.
    btw anong pede mong ma advice sken between santa fe and rav4?
    nalilito kac ako kung anong bibilhin.
    #844
    Quote Originally Posted by jolobots View Post
    Off Topic. :doh: :headache:
    Feb 2010
    #845
    Quote Originally Posted by rover2027 View Post
    sir maybe your clutch is slipping,try the clutch tests put gear in fifth and observe if engine dies ok pa clutch mo and if not slipping na clutch mo.ung oil leak if its coming from the hose it maybe blowby oil papunta ng turbo charger to exhaust it outside.try cleaning ang checks hose connections.if it persist a repair or replacement is needed.
    kung mahina na hatak, malamang manipis na clutch disc nyan, pa-check mo na transmission mo at baka pati flywheel madali.
    Feb 2010
    #846
    Quote Originally Posted by Jie11 View Post
    magandang gabi po! i've been following this thread and did observe that sir dieseldude was been a great help to most.
    sir pahelp din po. mausok po yung fortuner V ko pagkapaandar ku sa umaga, then maalog yung makina for a few seconds then maging ok na po cya. I had may change oil with petron trekker the other day but its still the same, no improvement. nagkaganito lang po mula nung nagkrudo aku sa province.
    I suspect the diesel which i used in the province at a petron station where they directed me on the line for the jeepneys., naubos po kasi yung no discount lane nung gasolinahan. nagfull tank ako at d pa po nauubos.
    anu po kaya maganda gawin ku, Thanks a lot
    ipa-check mo injector baka madumi na.
    Oct 2009
    #847
    Santa fe...
    Aug 2010
    #848
    Quote Originally Posted by Dieseldude View Post
    This is probably a supply pump problem which can easily be fixed.
    Pina diagnosed ko last couple of weeks and they said that it's the Suction valve. Need to replace it, common problem because of the dirty diesel in the Philippines is that possible?
    Sep 2008
    #849
    Quote Originally Posted by ocean explorer View Post
    thank you sir ocean explorer, my fort does not have that smoke already upon starting the engine since yesterday. God Bless po!!!
    Feb 2010
    #850
    you're welcome!
    Feb 2010
    #851
    Quote Originally Posted by ajOT View Post
    may I ask on what do you mean by putting on the 5th gear transmission? from start shift to 5th gear without goin to 1st gear and so on?
    if the clutch is somewhat slipping, what is the remedy?
    thanks.....
    No, the other guy mean, for example you're running on the highway or expressway, or some places where do you think you can shift her up to 5th. gear, kasi once na ginawa mo yung from neutral to 5th. gear kaagad,kakalog ang makina mo at may tendency na mamatay pa ang makina depende sa bitaw mo ng clutch, the reason is, kung manipis na ang clutch disc, once you reach the 5th. gear, instead na bumilis pa sya, babagal ang takbo nya kasi hindi na maka-kapit yung disc sa flywheel or pressure plate, so, shift it to lower gear. You can try also, once you shift to first gear, bitawan mo yung clucth dahan-dahan, normally kung ok yung clutch disc, medyo tumatalon pa sasakyan at saka mabilis reaction nya, aarangkada kaagad yan, pero kung manipis na at sliding, mabagal ang reaction nya, tatakbo pa rin pero malamya or parang tinatamad na tumakbo.
    Ang kailangan don, palitan ang clutch disc, pabaklas mo yung transmission, about one day ang consumption sa trabaho don depende pa kung saan ka magpapagawa.
    Kasi two times ko nang na-experience yan sa mga sasakyan ko, once na napalitan yung clutch disc nyan, babalik sa dati ang takbo yan.
    Aug 2010
    #852
    Quote Originally Posted by michaelgalas View Post
    Hope hinde to OT
    If I may ask, if they say na dirty diesel what exactly it means? Dirty in what way?
    I ask this because I am working in Military bases, most of available fuel here are what we called JP-8 not lubricated like diesel fuel, JP-8 fuel grade are used in Military vehicles. What we are doing is that we mixed used oil (but it under goes to cleaning, but not as clean as new oil) to JP-8 to make it diesel grade coded DF-2, pero yung used oil na yun came from our power plant generators and we then use the DF-2 to feed our generator ulit and all our diesel vehicles. (sometimes we use pure JP-8 sa mga sasakyan).
    Nasabi ko to kasi most of our trucks are Hilux 2.5, Hi-ace, Strada, Ranger and all American trucks na from F250 to 450 also sa may avatar ko Excursion. Ok naman
    #853
    thanks for that explanation....
    sometimes when I drive my Innova, from N to 1st gear kaunting bitaw lang ng clutch eh andar kaagad; am sometimes doubting na din aboiut my clutch housing or may be something else....
    Sep 2006
    #854
    Supply pump or suction valve has probably failed...... but not because of dirty diesel.
    "dirty diesel" is a lame excuse often made by some dealers.
    #855
    Sir, if I may ask; if dirty diesel is a scapegoat or lets say the lame excuse from the dealer; the real culprit on these then, that, the fuel pump of most Toyota are faulty or not working as to how it is expected to work?
    what can be the remedy for these cause, as we already own a Toyota car now!?! we just cant cry over spilled milk on these; do they have any remedial on these? what does the public do about these?
    Sep 2006
    #856
    Sir, if I may ask; if dirty diesel is a scapegoat or lets say the lame excuse from the dealer; the real culprit on these then, that, the fuel pump of most Toyota are faulty or not working as to how it is expected to work? That's how it looks.
    what can be the remedy for these cause, as we already own a Toyota car now!?! we just cant cry over spilled milk on these; do they have any remedial on these? Yes, they came up with an improved supply pump. But you have to pay for it....
    what does the public do about these? I don't know.
    Sep 2010
    #857
    Balak po namin bumili ng Hi-Ace GL Grandia. okay lang po ba yun? pagkatapos ng mga nabasa ko parang nakakatakot na tuloy.
    #858
    thanks for the reply
    that can be not so good fact, though, but I believe we have nothing to do with these things around as we have to live with it now......
    I think for Toyota; its always been, Business as Usual.
    Aug 2008
    #859
    Quote Originally Posted by andycapp View Post
    Bought my unit November 2007 din, so I have a few months left before my warranty expires.
    Hope your problem disappears after the ECU reprogramming and replacement of SCV. Worst scenario is to change the pump assembly which costs north of P70,000.
    gud day bro, up to now wala pa din available SCV for my innova its been a month na, sabi sa akin ng SA orderin pa daw ng planta sa abroad yung part.
    Mustahin ko lang din tol unit mo after mapalitan din ang SCV , hope ok na ok na.
    Sep 2010
    #860
    Quote Originally Posted by jefskie View Post
    BUMP ko lang po itong question ko. thanks
List of Toyota D4D Probems (Choking, Hard Starting, etc.)
