Results 1 to 18 of 18
    Feb 2005
    I am a MT driver for 8 years and have never driven an AT. My Fort will be arriving middle of November and I do not know anybody driving an AT vehicle and so, I cannot test drive. Please share your expertise on how to drive an automatic vehicle and do include tips.
    Thank you for all those who will be kind enough to respond.
    Just put in on 'D' and use the gas and the brake pedals as you see appropriate. The brake is used to moderate your speed (vs. lowering your gear in an M/T, or stepping on the clutch pedal)...
    When you park,- put the tranny on 'P'. Else, if you leave it on 'D', depending on the make and model of your A/T, you may not be able to remove your key or restart your car...
    Always step on the brake pedal when you shift from P to D/R =or= D to R =or= R to D =or= R to P et al . It will be advisable to just remove your foot from the brake pedal and observe how the car is moving, before stepping on the gas....
    6808:frenchyf1:
    Dec 2004
    in addition...
    you can shift to N (from D) if you're stalled for a while (waiting for the stoplight, traffic, etc). remember that being in D will give your car the tendency to move.
    P in A/T means you're to turn off the engine. when actually parking, still use D and/or R. most A/T vehicles today won't allow you to pull the key out if not in P when the engine's shut down (and bad din daw for the engine).
    use only your right foot for both gas and brake pedals. you can have your left leg cut and still drive an A/T (and find easy parking at the same time hahaha).
    when taking long trips, being along heavy metal cds as it gets boring driving automatics on straight and open highways.
    Jun 2006
    Add ko lang. When you park on an incline, set hand brake before you shift to P. If you put the car into P before seting the handbrake, there is a chance that the weight of the car will set on the transmission and it will be hard to get it into D.
    This is not a problem with small cars. But since you have a SUV, keep it in mind.
    Oct 2008
    you can actually switch from D to 3 for engine braking instead of hitting on the brakes. the gate type transmission is easier. D means drive uses gears 1-2-3-4 but when you shift to 3 it will only use gears 1-2-3.
    when on P (park) press on the brakes since when you switch to D (drive) the vehicle will immediately move forward slowly
    Dec 2008
    Is there an economical way to drive an automatic to save fuel? e.g. will it damage the tranny if you put it to Neutral from D while coasting?
    May 2007
    Quote Originally Posted by xcntrick View Post
    Thats a no no! You want an stick shift not an automatic. Good maintenance, do not step on the gas pedal more than you need is the best way to save gas.
    Jan 2009
    Always coast in gear. If your ECM/PCM is smart enough, it will cut power to the injectors to reduce fuel consumption. Shifting to N is both dangerous and not fuel efficient. It will require the engine to keep the injectors running to keep it in idle RPM (less fuel economy).
    Dec 2008
    So our FC is really at the mercy of how good is our ECM and how light footed we are.
    Thanks for the replies!
    and proper timing on shifter gears would add to a better FC.
    kambisaduhin mo ang car mo and malalaman mo kung paano i-dictate ang gers shifting nyan.
    Jan 2009
    Quote Originally Posted by s_quilicot View Post
    Hindi ata nag shift sa automatic. Parang D (or D2...D3 etc) lang. Unless CVT in manual mode.
    To save gas with an automatic be less of a gas stepper or brake stepper. The more you step on either gas or brake the more you consume gas.
    Try you tube. A lot of gas saving tips there. One useful tip - for city driving never load your tank full. A full tank weighs heavier (albeit more gas) than a half or a third filled tank.
    Feb 2009
    guys, when's the appropriate time to use "2" & "L". what should i use on steep descent? ascent? sorry, i've been on MT all my life. 1st time to go A/T last week with the arrival of our new innova G gas A/T. thank you.
    Quote Originally Posted by OldSchoolHack View Post
    i mean you can shift early to the next gear by doing a trick on the gas pedal.
    Quote Originally Posted by Theus View Post
    you could use both them on steep descent and ascent.
    L is for very steep and 2 is slighty steep .
    also its the engine break of the A/Ts.
    HTH
    Jan 2009
    L and 2 are basically the same with your M/T 1st and 2nd gear, respectively. Use it as you would on a M/T. When you shift to either gears, the tranny is locked in that particular gear (doesn't shift up or down). Use them when you're hauling up a steep hill or you need more engine braking going down.
    Those gears are provided because if you use D, there's a big possibility that the tranny will cycle to 3rd and/or 4th gear, which may not be desireable in certain driving conditions.
    Dec 2007
    This is a good time to read your manual, sir.
    Sa Avanza manual, ganito ang sinasabi:
    HTH.
    Feb 2009
    thank you. yeah, read the manual before, not much explanation though. may have missed it, but avanza manual's much better!
    Just a question. The new fortuner doesnt have an "L" gear but instead has S1-S6... Is S1 equal to L?
How to Drive an Automatic (Fortuner)
