Results 1 to 18 of 18
    My LC80 (not converted) 4.2L Tdi, A/T, currently emits a weird sound. When you accelarate it abruptly, out comes a 'whistling like sound'. This occurs even in low speeds as long as you accelarate it abruptly. If you drive normally, the sound does not come out even at high speeds. The sound does not affect the performance, or so I think, but its really bothering. This wasn't there before. Any advice? Thanks in advance.
    Dec 2002
    Turbo bearing worn? Loose air intake fittings?
    Try using a thinner oil like 15w40 or full synth 5w40.
    hindi kaya sa speakers ng radio? just a thought. How about the belts fan, a/c, etc. Could be the alternator or idler bearings. is it coming from your hood or just at the shift lever (floor)?
    i can't tell where its coming from but its definitely not the speakers, the sound depend on the acceleration eh not the speed, ur guess is as good as mine. u guys know any expert where i can have it checked? i tried toyota q.a. and they just told me its normal, what dumbasses
    One thing i would check out first would be the turbo...
    Jan 2004
    di po ba normal yung whistling sound na yun? i thought it's just the sound of the turbo kicking in. :confused:
    Jan 2004
    OT: di ba nakakasira sa diesel engines kung mag accelerate ka abruptly? :confused:
    Jan 1970
    I've had this "whistling" sound emanating from the turbo since day one that I acquired the LC80; but then, my unit is not brand-new upon acquisition, hence I am not sure if this is a defect or just normal with this 1HD-T engine. Whatever it is, I have no qualms with the sound, in fact, I like it.
    there's the sound of the turbo, but the "whistling sound" im referring to is something different. im sure this is not normal because this is the first time the sound came out after years of using it. quindoyos, ur right, its not good for the engine but the reason im asking is not to accelerate it abruptly but merely because it wasn't there before and might turn into a serious problem in the future.
    i had the same problem before na meron lang sound pag hard acceleration.. baka nga sa belt lang yan... nung pinaadjust ko nawala na yung sound..
    lc80,
    nabuhay ka ulit..
    ok thanks lc80, will try that
    May 2004
    tingin ko may singaw yan sa exhaust manifold... baka busted na yung O ring leading to the main pipe. nangyari na rin kc sa 2LT ko yan eh
    kc,
    nakalimutan ko kase password ko hehe... ngayon ko lang nahingi uli...
    the belts were not the problem, ok will try that re. the exhaust manifold thanks
    Originally posted by lc80
    kc,
    hehe... ganyan din si happiman ah. welcome back.
    alfred,
    hirap ng tumatanda na hehe
    double meaning yata he..he
    j/k
LC80 Problem, Help!
