Results 1 to 17 of 17
    Jun 2020
    Hello,
    Kakabili ko po ng second hand na vios 2019. Yung plate number po is conduction sticker plate. Sabi po sa akin ako daw papagawa.
    Pwede ko ba gamitin yung car kahit temporary plate? Hindi po ba ako mahuhuli?
    First time po kasi kaya madami po tanong. [emoji28]
    Thank you po.
    Sent from my RMX1971 using Tsikot Forums mobile app
    Yup it's fine. Most people use homemade plates.
    As long as the conduction number is displayed correctly:
    Sep 2006
    Tsk, those rims!
    Jun 2020
    Thanks po. Pag nakapag pagaw po ng plaka, kelangan po ba pumunta sa LTO para register o pwede na po gamitin agad?
    Quote Originally Posted by hunnybunny View Post
    Confusing yung question.
    Your car is already registered, plates are paid already.
    Release na lang nung plates inaantay mo.
    Temporary plate ba ibig mo sabihin with your conduction sticker details? Kabit mo lang ayos na yun.
    Kabit mo lang.
    nopo. as they already said above, ikabit nyo lang po.
    LTO already has all the identification information.
    the home-made (un-official) plates are for ease of identification on the roads.
    what you should ask, is where and when do you claim your official plates once they are released.
    Dec 2019
    No need nang pumunta ng LTO after you have just made the custom conduction sticker plate. Registered na ang Vios mo.
    Sep 2006
    Hello,
    Thank you po.
    I'm guessing wala pa yung actual plate mo no? If that is so, you may use the conduction sticker plate. Marami gumagawa nyan. Sintra board para medyo matibay.
    Mar 2018
    What if you already know the plate number, can you use a temp plate using this number instead?
    Sent from my SM-G975F using Tsikot Forums mobile app
    Quote Originally Posted by RavenBlack View Post
    ganun nga dapat.
    yung iba kasi,
    mas pabor sa kanila ang conduction sticker, because of coding needs.
    Sep 2006
    Sabi ng LTO hingi ka dapat ng authorization from them to make your plate using that identified plate number(virtual plate). Sabi nila.
    nakaka-inis, 'no?
    sila na nga ang may kasalanan at walang mai-abot sa atin na plaka,
    tapos tayo pa raw ang pupunta sa kanila para humingi ng authorization,
    tapos tayo pa magpapagawa nang sarili nating gastos...
    dapat ganito.
    sa pag-abot pa lang ng OR CR, dapat ay,
    "heto na rin po ang assigned plate number nyo. bahala na po kayo kung san nyo nais magpagawa nyan. sundan nyo lang po yung disenyong naka-saad."
    Jan 2016
    Reviving the thread, so lumabas na ORCR ko, and it has a plate number indicated, so based on posts here, mukhang mas mabuti pa na iwan ko na lang ung conduction sticker na plate provided by dealer kesa magpagawa ng temporary plate using the indicated plate number at need pa humingi authorization sa LTO. Is this right until now?
    Dami kong nakikita na yung flimsy plate lang na bigay ng dealer ang gamit, they don't even put the MV number, parang mas I was sita ito? I checked Lazada for temporary plates and may nag comment na nahuli daw sya ng HPG kasi walang authorization.
    i am confused.
    some time back, government admitted they couldn't produce the plakas fast enough, and that car owners may make their own makeshift plakas, based on specifications (font type and size).
    have they modified the rules, making it a requirement now that car owner has to get permission to make/have made these temporary plakas?
    personally, i would leave the conduction number plates in place,
    para hindi na gumastos o magpakahirap pah.
    i saw an online document from kotse ni phil dat khom, dated aug. 2020.
    while the specs for the temporary plates are mentioned, it does not specify requiring a permit from LTO, to make one's temporary plates.
    Jan 2016
    I googled topics about this and the latest directive was a temporary plate with the conduction sticker number and other formats. Nothing on, what if the, the ORCR has a plate number issued on it.
    Although there was a mention that the dealer should only release the vehicle with an orcr, this is not being followed and so you got a flimsy plate with the necessary format and conduction number but empty MV# and issuing office. Pwede ko kaya i-pentel pen na lang ito.
    i think puede ang "ginawa-sa-bahay".
    but one must always see to it that the "temporary plates" are securely attached. it is your duty as car owner.
    meron kasing nag-sound-off dito, that his temporary plates tore off and he was flagged down and penalized for it.
Conduction sticker
