Results 1 to 6 of 6
- Mar 2004
- 89
August 18th, 2008 12:38 AM #1yung shocs ko parang basa nang oil yung driver side na front... sira na ba to? tsaka parang iba tunog nung dumaan ako sa highway pag dumadaan sa uneven pavement.... how much ba ang shocks? puede ba isa lang palitan?
kasama ba sa warranty ang shocks? la pa 1 year to eh
August 18th, 2008 01:20 AM #2
August 18th, 2008 01:39 AM #3
bnew KYB gas shocks (1pc) will cost you 1.2k - 1.5k (inquired last week * Mindanao Ave.), yung KYB fluid shocks naman, siguro kasing price lang ng gas shocks o baka mas mura pa pero for sure not more expensive than the gas shocks. But some, may nagbebenta as much as 1.8k each...about sa warranty, alam ko meron, pero di ko lang alam kung gano katagal or depende din sa shops siguro...
about sa check up ng pang-ilalim mo lalo sa sa shocks, go to cruven, they are the experts at this...and also, cruven is also doing fluid-to-gas shocks conversion...
http://www.cruven.net/
__________________
passion for fashion? craving for savings?
visit MAI PASSION boutique at the fashion village * Tiendesitas
August 18th, 2008 01:40 AM #4
__________________
August 18th, 2008 11:14 AM #5
Front shocks for Innova are more expensive than the rear. Front shocks costs P1,200 apiece, while the rear its P768. It's certain that your front shock/s is leaking if you observed traces of oily residues outside the housing more so when you experience bumpy ride unlike before. Since your unit is just a year since you acquired it, the part is still under warranty. I suggest that you visit your dealer and have it replaced, on both axles as a vehicle tends to list on a side with older shock absorber. Better if you contact them first and inquire part availability before bringing your unit to them.
OT: Mods kindly edit the word on the thread title "fron" to read "front" TIA.
- Mar 2004
- 89
August 20th, 2008 03:30 PM #6thanks a lot sa mga replies po .... sorry din mali spelling nang front, kaka madali kasi...
i shall assume your radiator cap is not leaking. does the coolant boil, as in, bumubula, in the...
Nababawasan ang coolant sa reservoir honda civic
