Results 1 to 7 of 7
    I am driving a 2007 Toyota Vios (a/t).
    My problem is on the "N" indicator in the dashboard. When I shift to the Neutral gear, hindi umiilaw yung N sa dashboard. Pero kapag naka-shift naman sa Drive, may ilaw naman yung "D".
    Sa tingin ko hindi bulb yung problema kse umiilaw naman kapag "D" and nasa same position lang naman sila sa dashboard. Tama ba ako?
    Ipatingin ko sana sa Toyota Service Center kaso ang sabi, 1,800 php na agad diagnosis fee pa lang ... wala pa yung repair kung sakali ...
    So far, wala naman akong nakikitang kakaiba sa performance ng kotse kaso nag-aalala lang ako baka indicator na yun na may problema sa electrical wirings sa loob ... need advice c",)
    Sa P, R, and other D positions,- umiilaw ba?
    Sa position N,- hindi ba gumalaw ang sasakyan kapag hindi ka nakatapak sa preno?
    Baka pilot bulb lang iyan....
    12.3K:outcold:
    12.3K:outcold:
    thanks sa reply...
    umiilaw naman sa P,R and D and wala naman akong nararamdaman na unusual kapag naka-neutral. and di naman gumagalaw sasakyan kapag naka-neutral.
    ano ba pinaka-ma-ok na strategy na gawin kung dadalhin ko sa toyota service center para ipatingin?
    Jan 2003
    you can DIY removing the cluster gauges. malamang bulb lang yan, wag lang blinking "D" meaning may problema A/T
    Jul 2010
    sir bulb lang po yan, may kakilala ako ganyan din problem yung "N" walang ilang pag nasa neutral, pinalitan lang po. madali lang po yan, sobrang mahal naman yung 1,800 na sinisingil sa inyo.
    Quote Originally Posted by ungas2010 View Post
    I have the same problem with my '99 Corolla A/T. One of the dashboard indicators (for the shifter position) does not light up sometimes. Sometimes it does light up. I assumed it was a loose bulb/LED/contact. Never had it fixed though.
    BTW, in my case it is the "D" that doesn't light up.
    napa-check ko na sa toyota finally, may loose wiring kaya ayaw umilaw sa N.
    tubong-lugaw talaga toyota service ... kaya mayaman may-ari ng toyota
Disappearing "N" Light on the Gauge Dashboard
