Page 1 of 5 12345 LastLast
Results 1 to 20 of 82
    May 2013
    Hi,
    In about a month we'll be getting a 2.5G A/T Fort. I've been reading about EGR blanking and am thinking of doing the mod as early as possible. In fact, if it were up to me, I'd have it fitted before leaving the dealership. Still, I have a few questions gor those who've done it(on a fort or other d-4d equipped toyota).
    1. Have you ever gotten a CEL go off or a crash into limp mode post-EGR blank?
    2. I'm planning to DIY the plate fabrication and install, any ideas what material would be best for this?
    3. Is the blanking detectable during an OBD scan(warranty concerns)?
    Thanks in advance!
    Sent from my HTC One X+ using Tapatalk 2
    We blank the egr on the patrols so that the cel will not go on (due to excess carbon build up in the manifold).
    The blanking if done properly cannot be detected by a computer scan or even a technician looking into the engine unless he disassemles it.
    Try getting in touch with sir jun, the owner of diesel king malabon diesel, he is our go to guy for egr blanking. They service the d4d vehicles of nlex and other fleet accounts.
    Feb 2013
    Dependent ang computer scanning sa sensors, as long as your sensor readings will not be affected by your modification, it will not be detected by a computer scan.
    Mas nagkaproblema pa kami sa sensor when the egr blanking plate failed, the carbon fouled up the egr sensor and sent the vehicle into limp mode. A new blanking plate solved it.
    Doc paano nagfail yung blanking plate?
    Mahina yung bakal na nagamit namin, natunaw ng hot exhaust gas so nag-recirculate ulit ang exhaust.
    Eventually anong metal ginamit doc? Sa akin G.I. sheet lang yata ginamit e. But have to check again cause may water injection na ako. Baka nangalawang na.
    Steel plate ata. Hehe. Isip ko nga lagyan ng hitemp primer pr paint baka makatulong
    Jul 2011
    congrats TS for the new fort, ingat sir research more if your fort is with VNT, from my understanding it has no wastegate unlike the previous turbo, vane type turbo is dumping mechanism to the EGR system you may CEL from blanking this,
    MIne is innova 2.5D, same engine 2kd-ftv different tweak from fort, i blanked initially with stainless steel plate, result smooth acceleration, i did not clean the EGR as the tube that connects from exhaust to EGR had not so much soot.
    tools and materials need:
    socket wrench with extension 4" and the other one long enough to crawl parallel to the intake manifold.
    steel plate
    what i did
    1. disconnect battery wait atleast 15 min, for me
    2. remove the engine design cover and its bracket
    3. remove plug near the exhaust side of the EGR tube.
    4. unscrew bolt at EGR side and nuts at engine side.
    5. cut the steel plate pattern to the gasket, much easier than pattern that holds the tube.
    6. depending of what size of your steel plate that can sandwhich to the tube or totally delete the tube very thick plate advisable is 5mm;
    install the plate. and redo in reverse order the above procedures.
    Sep 2011
    sir hindi po ba lalakas sa diesel kapag nag blanking plates ?
    No sir.
    Sep 2011
    No sir.
    thanks sir !
    mga sirs, any recommended shop near Fairview, QC where I can have this mod done? thanks!
    Aug 2005
    Sir, san po kaya pwede magpa blanking dito sa south metro manila area(parañaque, las piñas, muntinlupa area?
    Dr. G's Car Clinic is now selling and installing commerically manufactured egr blanking plates for fortuners. I think the plates are made in Thailand. They are in QC and have a webpage also.
    Apr 2013
    Mga sirs ask ko lang po kung san yung blanking points ng fort 3.0 engine? Planning to diy po. Much better po sana kung may pics. Thanks!
    Aug 2010
    any shop that do egr blanking in manila or makati area?
    Sila Jemson kaya gawin yan. You just point to them which part to blank as per Otep.
    Hmmm... Di ko pa gimagawa ito sa Hiace and Innova...
    Vinj, may mga nabibili na aluminum blanking plates for 2.5d4d from Thailand. Nakita ko sa fortuner club. Meron din daw kay dr.g nakapost sa taas. Alam ko 1/2 inch thick aluminum plates siya. Tanggal na talaga EGR.
    Si bro Zix alam ko gumagawa din ng blanking plates, pero mas manipis yata
EGR blanking a D-4D
