Results 1 to 8 of 8
    Sep 2006
    Good Morning all...
    Newbie hir!
    Just bought a second hand 1995 toyota corolla XL.
    Di ko sya na test drive ng ganun katagal and katulin, probably mga 30-40 lang ako.
    Until last friday, on my way home from work mga 11pm C5-Pasig, naka 90 ako. Noticed that when i'm *80 above, the car started to wiggle.
    Need some help from the veterans please....
    Also, since this is my 1st time na magkaroon ng kotse, need you expertise ma'am / sir on a daily, monthly, quarterly basis check-up routine.
    As in blanko po ako pag dating sa kotse.
    That's why this is the best 1st move siguro, open a thread.
    Hope to hear from you guys.
    Thanks po!!!
  2. #2
    sir try to check the wheel alignment, also the thread wear of your tires. Pa check mo na rin yung suspension parts baka worn out na.
    Sep 2006
    or better yet, ipaful service checkup tuneup change oil mo sa Toyota mismo. Magsheshell out ka nga lang ng malakilaki since wala nang warranty.
    Apr 2005
    Quote Originally Posted by tres21 View Post
    Good Morning all...
    Newbie hir!
    Thanks po!!!
    the most commn causes of wiggle are wheel alignment or wheel balancing.
    Have it check by a competent mechanics or bring it to servitex .
    Bago pa ba gulong? Yug sa akin kasi pagkapalit ko ng apat na gulong nawala na rin yung wiggle nya.
    tingnan mo condition ng goma mo kung ok pa baka me oblong na di na pantay ang kain etc...pa balance mo and alignment or pa check mo na din camber para isang salangan na lang.
    May 2007
    oo nga... tama... minsan nasa gulong yung deperensya kaya na-wiggle... kasi pag di magandang klase yung gulong mo tapos parang na-oblong or naiba parang na deform,sigurado wiggle yun . kahit wala walang diperensya yung nga tie rod mo. may you can try, pa-wheel balance ka. tapos pa check mo na rin condition nung pang harap mo, pa check mo yung mga greasing ng mga ankles.
    Jun 2007
    Good Morning all...
    Newbie hir!
    Thanks po!!!
    dali lang yan prob u.....pa check mo ang tie-rods, pti rack&pinion console mo, after if may makitang clearance, den palitan mo....most of all, nasa gulong din yan, palit ka ng bago, may umbok ang tire mo, need to replace it, hnd kaya ng balancing yun
Help on wiggle!!!
