Results 1 to 8 of 8
May 10th, 2008 11:26 PM #1
mga sir.. help naman po.. kasi ayaw mag off yung tail light ng kotse ko kahit off ko na lahat at wala na yung susi.. ano po ba ang dapat kong gawin? tinatanggal ko ung connection sa battery pag naka park aku para di madiskarga.. san ko pu ba pwede ipagawa un na malapit lang sa manila.. thanks po!
May 11th, 2008 01:55 AM #2
Look at your brake pedal where the rod goes up under the dash. There is switch acts like a big click type pen and when you push the pedal the rod comes away from the switch...letting the plunger out which activates the lights. It may need to adjusted back or spray it with WD40 to lubricate the switch plunger, if does not work replaced the switch..cheap and easy to install.
May 11th, 2008 02:41 AM #3
i'm not familiar w/ toyotas but maybe the rubber stopper on your brake switch (located on your brake stalk) is already broken. as bro v6 dreamer has said, it's quite easy to locate and to fix or replace
May 19th, 2008 10:00 PM #4
hello mga sirs.. sabe ng electrician yun stoplight daw ang problem niremedyohan nalng nia.. paid 150 for his service.. tapos ok na ulet.. hehehe.. tenks sa mga reply..
May 19th, 2008 10:37 PM #5
check your brake fluid. baka mashado na mababa. bumabaon na yun brake pedal
May 20th, 2008 04:14 AM #7
May 20th, 2008 07:29 AM #8
ah stop light pala problema....magaling! joke nababaha ka no? seriously, ngayong tag-ulan uso yan dahil sa moisture build up kaya WD40 lang sa break pedal switch. pag naulit, pakiramdaman mo rin ang break kung may dikit. malalim ba break pedal mo?
