Results 1 to 8 of 8
    May 2008
    mga sir.. help naman po.. kasi ayaw mag off yung tail light ng kotse ko kahit off ko na lahat at wala na yung susi.. ano po ba ang dapat kong gawin? tinatanggal ko ung connection sa battery pag naka park aku para di madiskarga.. san ko pu ba pwede ipagawa un na malapit lang sa manila.. thanks po!
    May 2007
    Look at your brake pedal where the rod goes up under the dash. There is switch acts like a big click type pen and when you push the pedal the rod comes away from the switch...letting the plunger out which activates the lights. It may need to adjusted back or spray it with WD40 to lubricate the switch plunger, if does not work replaced the switch..cheap and easy to install.
    i'm not familiar w/ toyotas but maybe the rubber stopper on your brake switch (located on your brake stalk) is already broken. as bro v6 dreamer has said, it's quite easy to locate and to fix or replace
    May 2008
    hello mga sirs.. sabe ng electrician yun stoplight daw ang problem niremedyohan nalng nia.. paid 150 for his service.. tapos ok na ulet.. hehehe.. tenks sa mga reply..
    Nov 2006
    check your brake fluid. baka mashado na mababa. bumabaon na yun brake pedal
    baka nga brake fluid ..
    anung bang umiilaw na light? yung 5w or 21 w?
    May 2007
    Quote Originally Posted by pasawaytoh View Post
    Haaaa! What exactly did he do? Think of it, lights are after the switch and lights wont turn on if the switch or power is open. This is new to me at paki tanong lang kung paano niya ginawa with theory dahil dagdag kaalaman ito.thanks
    ah stop light pala problema....magaling! joke nababaha ka no? seriously, ngayong tag-ulan uso yan dahil sa moisture build up kaya WD40 lang sa break pedal switch. pag naulit, pakiramdaman mo rin ang break kung may dikit. malalim ba break pedal mo?
help: tail light ayaw mag off kahit wala na susi
