Results 1 to 10 of 11
November 8th, 2007 10:26 AM #1
hello mga bro, kindly help naman sa 2c turbo (japan) ko 2x na dukot still kumakain pa rin ng langis ayaw ko na sana ibenta kc mlaki na gastos ko,can u give advise me or mgandang suggestion. your help is highly apprecuiated.tnx.
November 8th, 2007 12:30 PM #2
Have a compression test done first (wet and dry) so that you can determine what exactly is the cause of the loose compression. Also, "dukot" isnt really an adviseable way of properly overhauling an engine. On our 1300 Corolla before, i changed all the gaskets and piston rings using original parts and it didnt cost more than 15K (just shop around for the parts yourself).
November 9th, 2007 05:40 AM #4
compression test nga:
here's a data of 2c-t's
http://tsikot.yehey.com/forums/showthread.php?t=40308
might be good to let us know any other things you noticed ex. like hard start, white smoke idle, etc...
November 9th, 2007 11:23 AM #5
not really a hard starter but emits white smoke, ang idle not really good very shaky specially when it is cold, and there a smoke coming out on my dips stick. some of friends told me that the turbo may be damage also pero mlkas pa rin ito humatak, should i replace my engine?or can be repaired? how much will it cost me?thanks.
November 11th, 2007 01:39 AM #6
if smoke coming out on dipstick, have a compression test...
use the data.
if only the white smoke emits on idle after pushing hard the engine. example: after a stop on traffic lights, the smoke appears.... then it's likely the turbo.
a 2c-t surplus costs 18k-up.Last edited by rion; November 11th, 2007 at 01:43 AM.
November 11th, 2007 10:54 AM #7
Bakit 2 beses ka nagpadukot?
How is your liner/sleeve? Honing? Oversizing of rings? Piston grooves?
Turbo noise (sayad/m.m. contact)? Oil soaked intercooler(if any)?
There are 4 possible outlets of oil that should be maintained at a minimum or zero
1. Oil seal of turbo
2. Oil seal of valves
3. Oil ring of piston
4. Oil seal front and main(0)
November 12th, 2007 02:50 AM #9
baka hindi yan na set ang valve clearance sa machine shop.
you can get info about 2ct overhaul in alwayz_yummy web page
http://www.cardomain.com/ride/2327061/3
the data link I posted has a valve clearance size setting.
November 12th, 2007 10:46 AM #10
thanks mga bro for replying to my prob. it is a big help for me, maybe you were right i should change my mechanic, 2 times na dukot kasi it gaves me same problem malakas kumain ng langis. so, your suggestion is it can be repaired not like other say that 2c are disposable engine.
Monk-owned R53
