guys i need your inputs.yung AE92 ko na 16valve carb pag naka aircon it experiences hesitation on low speed.pag hindi naka on ang AC e ok naman.ano ang pwede ayusin considering na new and high tension wires at spark plugs.newly seated ang valves at new valve seals.sa crab vacuum kaya ang problema?sa timing kaya ng engine?
Sir, when you say hesitation meaning nag low rev ang engine mo then high rev while driving on a low gear? Kung ganun ang nagyayari mukhang clutch yan nung aircon mo, have you tried experimenting with your engine idle?
i've fixed it already.may singaw sa carb at malfunctioning na pcv valve.binalilik ko sa stock and tubings sa makina as per researched.thanks sa mga inputs ngnagreply
