Results 1 to 4 of 4
- Jun 2009
- 21
July 5th, 2010 11:17 PM #1guys i need your inputs.yung AE92 ko na 16valve carb pag naka aircon it experiences hesitation on low speed.pag hindi naka on ang AC e ok naman.ano ang pwede ayusin considering na new and high tension wires at spark plugs.newly seated ang valves at new valve seals.sa crab vacuum kaya ang problema?sa timing kaya ng engine?
- Apr 2010
- 9
July 7th, 2010 08:04 AM #3Sir, when you say hesitation meaning nag low rev ang engine mo then high rev while driving on a low gear? Kung ganun ang nagyayari mukhang clutch yan nung aircon mo, have you tried experimenting with your engine idle?
- Jun 2009
- 21
July 7th, 2010 10:16 AM #4i've fixed it already.may singaw sa carb at malfunctioning na pcv valve.binalilik ko sa stock and tubings sa makina as per researched.thanks sa mga inputs ngnagreply
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
