Results 1 to 4 of 4
    Apr 2009
    sa mga nakaBT 20v po diyan, ask ko lang saan kaya tayo makakasource out ng thermostat pang BT?
    i'm not sure if this is my problem pero i just noticed everytime i drive on freeway, my temp gauge drops thus making my engine running cooler on high speeds which is, sabi bad for the engine in the long run...
    every morning, it takes 5 mins before it warms up...
    when open A/C sa freeway, di naman nagddrop yung temp niya... stable yung needle sa tamang operating temp niya...(?)
    wala po akong coolant,. distilled water lang po.. do you guys think na malaking factor ang coolant sa thermostat? since the engine is outsourced from japan, coolant siguro ginagamit nila eh dito sa pinas karamihan sa atin distilled water lang oks na...
    kung meron man nakakaalam where to purchase thermostat for my 4age BT 20v sana matulungan niyo po ako... kung pwede isama niyo na po price...
    maraming salamat po...
    Apr 2009
    update ko lang baka may nakakaalam diyan
    Quote Originally Posted by MARCIAL View Post
    Bat di mo na lang lagyan ng coolant na pre-mix or concentrated since distilled naman pala gamit mo. Weather its imported or local model dapat naka coolant ang radiator, not only does it cool but it prevents the build up of rust. Curious lang ako, ano car yang nakakabit yang black top na 4age mo? corolla, trueno?
    Apr 2009
    up ko lang
HELP! 4age 20v BT thermostat
