Results 1 to 7 of 7
- May 2005
- 4
February 17th, 2012 02:21 PM #1Hi guys,
Where can I get spare parts for a 1999 Toyota 4Runner (US Version) 4x4 Gasoline AT - how hard is it to find parts for this vehicle?
February 19th, 2012 09:29 AM #2
Whats the engine code on that thing? Afaik, the 3400 vg is identical to the prado unit. Same with the front and rear suspension. Toyota can get parts if needed. Allow for a 2 day lead time.
- May 2005
- 4
February 20th, 2012 03:52 PM #35vz ung engine nya. I need rack and pinion but a bit worried if I there are parts for this (in case other major parts die on me). How much ang rack and pinion? Please email contact number to kernelpanix*gmail.com so I can call you
February 20th, 2012 04:03 PM #4
Sir I'm not in the car business. Yes the 5vz is same as the 90 series Prado.
AFAIK, the 4Runner also shares the same rack and pinion with the 90 series Prado. Your best bet would be Jojo L of Toyota Quezon Avenue Parts. He knows these things very well and can instantly have the part on order as needed.
February 20th, 2012 04:42 PM #5
Aside from what Otep suggested, try also NGK motor parts and WAS Auto Supply. Both are located in Banawe (E. Rodriguez side).
- May 2005
- 4
February 22nd, 2012 01:43 PM #6Thanks for the tips - however no positive results yet... mukhang mahirap talaga humanap ng US version parts
February 22nd, 2012 03:13 PM #7
Might be better to also ship in parts from the US if you have contacts there if that's the case.
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
